problem of building uclinux
hi
I met the following problem when I build uclinux with niosII ide:
Kind Status Priority Description Resource In Folder Location
Warning unused variable `fhp'[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/lockd/svcsubs.c] kernel_1c20 line 58
Warning long unsigned int format, size_t arg (arg 7)[/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/base/dmapool.c] kernel_1c20 line 73
who can help me ,thanks.
ok,I am success!
now I have run uClinux successfully on niosII (cyclone board)and configure my IP address on it.uClinux/Nios II
--- Quote Start ---
Altera Nios II support © 2004 Microtronix Datacom Ltd.
On node 0 totalpages: 4096
DMA zone: 0 pages, LIFO batch:1
Normal zone: 4096 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 16 (order 4: 128 bytes)
Memory available: 14596k/4096k RAM, 0k/0k ROM (1298k kernel code, 285k d
Calibrating delay loop... 24.62 BogoMIPS
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
POSIX conformance testing by UNIFIX
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.3 $
ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 50000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR
ed:0b:0c:6c
Using anticipatory io scheduler
microtronix[mtd]: RAM probe address=0x200000 size=0x1ee000
Creating 1 MTD partitions on "RAM":
0x00000000-0x001ee000 : "ROMfs"
microtronix[mtd]: set ROMfs to be root filesystem
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 44k freed (0x1172000 - 0x117c000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
/etc/issue www.microtronix.com July 2004
Welcome to Linux on the Nios II
Nios2 login: nios
Password:
Login incorrect
Nios2 login: nios
Password:
# ls
ftp httpd# ifconfig eth0 211.65.88.227 netmask 255.255.255.128
eth0:PHY 100BaseT
eth0:PHY Half Duplex#
yes,the next step is build a rw filesystem,that&#39;s very annoying http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
good luck http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
hi,tazok
do you know how to builder a rw file system?
I am a newer, can you help me?
thanks a lot.
--- Quote Start ---
originally posted by xlking@Dec 6 2004, 04:30 AM
hi,tazok
i am a newer, can you help me?
thanks a lot.
--- Quote End ---
To successfully build an rw filesystem copy the filesystem files on Compact Flash previously partitioned with an ext2fs on hda1, try mknod for all device in /dev directory, then specify the root=0301 in kernel config, recompile the kernel and upload it.
Good Luck
