12748 Discussions
problem to run nios2-terminal
I have installed Quartus and nios2 9.1 sp2 on centOS5 to use uclinux. Now i am using the example of the Nios Community WIKY called TryOutuClinux on DE2 board. I have downloaded the sof and and the kernel image but i cannot run correctely the nios2-terminal.
This is what happens in my shell:
" [NiosII EDS]$ nios2-configure-sof
Searching for SOF file:
in .
DE2_NIOS_HOST_MOUSE_VGA.sof
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Command: quartus_pgm --no_banner --mode=jtag -o p;./DE2_NIOS_HOST_MOUSE_VGA.sof
Info: Using programming cable "USB-Blaster [USB 5-1.2]"
Info: Started Programmer operation at Wed Jun 30 10:28:44 2010
Info: Configuring device index 1
Info: Device 1 contains JTAG ID code 0x020B40DD
Info: Configuration succeeded -- 1 device(s) configured
Info: Successfully performed operation(s)
Info: Ended Programmer operation at Wed Jun 30 10:28:46 2010
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 59 megabytes
Info: Processing ended: Wed Jun 30 10:28:46 2010
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:00
/tmp/primo_es_ulinux
[NiosII EDS]$ nios2-download -g
Using cable "USB-Blaster [USB 5-1.2]", device 1, instance 0x00
Pausing target processor: OK
Restarting target processor
[NiosII EDS]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB 5-1.2]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
And after this nothing appears on my screen
Thank you very much for every help
I think the problem is becuse when i download the linux image in the terminal i have only:
"Pausing target processor: OK
and after this the image is not really downloaded, but i don't know how to solve this problem
Sorry, i am solved the problem, the nios2-download doesn't search the image file in the folder as the command nios2-configure-sof so i need only insert the image name after the command.
Now i can run the terminal.
Sorry for this unseful thread.
