12748 Discussions
problem ,when i chose "debug as niosII hardware"
project build has been succeed ,but when i chose "debug as niosII hardware".
System hints:
you have more than one jtag cable available so you must use the --cable option
to choose between them (or open the "run/run" or "run/debug" dialog and go to
the "target connection" tab).
no --cable option was provided (or you selected automatic)
what is the reason?how to solve it?
It looks like you may have multiple cables installed. To pick the intended cable eg. USB-Blaster, go to the menu bar and select Run -> Debug... Select the Target Connection tab and select the cable of your choice from the drop-down list for the JTAG cable field. Then click on Debug, to start the session.
