hi all:
dm9000 driver is ok in blackfin 533,but it doesnt work well in 531.(not modified from 533),at first ,i cannt ping host ,for example ,the ip of board is 192.168.2.253,then in the board i ping 192.168.2.99,but it does not work. later i change int_status = ior(db, DM9000_ISR); /* Got ISR */ iow(db, DM9000_ISR,int_status); into int_status = ior(db, DM9000_ISR); /* Got ISR */ iow(db, DM9000_ISR,0x00); now i can ping 192.168.2.99,but response time is too long : PING 192.168.2.99 (192.168.2.99): 56 data bytes 84 bytes from 192.168.2.99: icmp_seq=0 ttl=64 time=1007.5 ms 84 bytes from 192.168.2.99: icmp_seq=1 ttl=64 time=1006.2 ms 84 bytes from 192.168.2.99: icmp_seq=2 ttl=64 time=1006.2 ms 84 bytes from 192.168.2.99: icmp_seq=3 ttl=64 time=1006.3 ms 84 bytes from 192.168.2.99: icmp_seq=4 ttl=64 time=1006.2 ms 84 bytes from 192.168.2.99: icmp_seq=5 ttl=64 time=1007.6 ms if i ping the board(ping 192.168.2.253) this time from another PC,then response is short: PING 192.168.2.99 (192.168.2.99): 56 data bytes 84 bytes from 192.168.2.99: icmp_seq=0 ttl=64 time=1006.9 ms 84 bytes from 192.168.2.99: icmp_seq=1 ttl=64 time=1007.1 ms 84 bytes from 192.168.2.99: icmp_seq=2 ttl=64 time=1007.7 ms 84 bytes from 192.168.2.99: icmp_seq=3 ttl=64 time=6.0 ms 84 bytes from 192.168.2.99: icmp_seq=4 ttl=64 time=1007.7 ms 84 bytes from 192.168.2.99: icmp_seq=5 ttl=64 time=6.0 ms 84 bytes from 192.168.2.99: icmp_seq=6 ttl=64 time=3.9 ms 84 bytes from 192.168.2.99: icmp_seq=7 ttl=64 time=3.7 ms 84 bytes from 192.168.2.99: icmp_seq=8 ttl=64 time=1007.7 ms 84 bytes from 192.168.2.99: icmp_seq=9 ttl=64 time=6.0 ms 84 bytes from 192.168.2.99: icmp_seq=10 ttl=64 time=3.7 ms 84 bytes from 192.168.2.99: icmp_seq=11 ttl=64 time=3.9 ms 84 bytes from 192.168.2.99: icmp_seq=12 ttl=64 time=3.9 ms 84 bytes from 192.168.2.99: icmp_seq=13 ttl=64 time=3.8 ms 84 bytes from 192.168.2.99: icmp_seq=14 ttl=64 time=4.5 ms --- 192.168.2.99 ping statistics --- 15 packets transmitted, 15 packets received, 0% packet loss round-trip min/avg/max = 3.7/338.8/1007.7 ms i ask for help thanksLink Copied
This is NIOS uClinux forum, not for BLACKFIN.
Please post your problems to blackfin's forum, they are very active and should help you out. http://blackfin.uclinux.org/forum/forum.php?forum_id=39 (http://blackfin.uclinux.org/forum/forum.php?forum_id=39)
