12748 Discussions
run websever base on boa and cgi on uclinux
dear all,
I want to run websever base on boa and cgi on uclinux,i am porting uclinux to nios2,now find the boa has some problem in the uclinux-dist-060511,could anyone modify it or send some message to the www.uclinux.org so the boa can be corrected ?
dear hippo,could you give me some advice?
--- Quote Start ---
originally posted by nwpu_zhf2004@Jun 19 2006, 10:48 PM
dear all,
    i want to run websever base on boa and cgi on uclinux,i am porting uclinux to nios2,now find the boa  has some problem  in the uclinux-dist-060511,could anyone modify it or send some message to the www.uclinux.org so the boa can be corrected ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16251)
--- quote end ---
--- Quote End ---
The newer boa , boa-new in Blackfin uClinux-dist works better.
Find it at the end of
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)
