12748 Discussions
problem with performance counter core
Hi everyone, I am a new to nios. I've been trying to get this code to work on the cyclone 2 development board that I have. I just don't know what is wrong. I cannot get any valid result from the performance counter core of altera. any suggestion is very helpful.
# include "alt_types.h"# include <stdio.h> /* This ert_main.c example uses printf/fflush */# include <unistd.h># include <altera_avalon_performance_counter.h> /*Use to measure code performance*/ # include "varipitch.h" /* Model&#39;s header file */# include "rtwtypes.h" /* MathWorks types */# define RATE0 1# define RATE1 2
extern const float GNC_input_table[33343][21];
static RT_MODEL_varipitch varipitch_M_;
static RT_MODEL_varipitch *varipitch_M = &varipitch_M_;/* Real-time model */
static BlockIO_varipitch varipitch_B; /* Observable signals */
static D_Work_varipitch varipitch_DWork;/* Observable states */
static real32_T varipitch_U_Xe[3];
/* Root inport: &#39;<Root>/Xe&#39; */
static real32_T varipitch_U_Ve[3];
/* Root inport: &#39;<Root>/Ve&#39; */
static real32_T varipitch_U_p;
/* Root inport: &#39;<Root>/p&#39; */
static real32_T varipitch_U_dpdt;
/* Root inport: &#39;<Root>/dpdt&#39; */
static real32_T varipitch_U_Q6;
/* Root inport: &#39;<Root>/Q6&#39; */
static real32_T varipitch_U_Cdsin6;
/* Root inport: &#39;<Root>/Cdsin6&#39; */
static real32_T varipitch_U_Cmas6;
/* Root inport: &#39;<Root>/Cmas6&#39; */
static real32_T varipitch_U_Vb[3];
/* Root inport: &#39;<Root>/Vb&#39; */
static real32_T varipitch_U_mass_single;
/* Root inport: &#39;<Root>/mass&#39; */
static real32_T varipitch_U_ix_single;
/* Root inport: &#39;<Root>/ix&#39; */
static real32_T varipitch_U_iy_single;
/* Root inport: &#39;<Root>/iy&#39; */
static real32_T varipitch_U_cg_single;
/* Root inport: &#39;<Root>/cg&#39; */
static real32_T varipitch_U_winds_single[2];
/* Root inport: &#39;<Root>/winds&#39; */
static real32_T varipitch_U_clock_single;
/* Root inport: &#39;<Root>/clock&#39; */
static real32_T varipitch_Y_Mode;
/* Root outport: &#39;<Root>/Mode&#39; */
static real32_T varipitch_Y_CMDP;
/* Root outport: &#39;<Root>/CMDP&#39; */
static boolean_T OverrunFlags[2] = { 0, 0 };
DEFINITION OF MYFUNCTION1{}
DEFINITION OF MYFUNCTION2{
PERF_BEGIN(PERFORMANCE_COUNTER_0_BASE, RATE1);
do something
PERF_END(PERFORMANCE_COUNTER_0_BASE, RATE1);
int perf_print_my_formatted_report (void* perf_base, alt_u32 clock_freq_hertz)
double total_usec;
alt_u64 total_clocks;
alt_u64 section_clocks;
int section_num = 1;
const char* separator = "+---------------+-----+------------+---------------+-----------+\n";
const char* column_header = "| Section | % | Time (usec)| Time (clocks)|Occurrences|\n";
total_clocks = perf_get_total_time (perf_base);
total_usec = ((double)total_clocks) / clock_freq_hertz *1000000;
// Print the total at the top:
printf ("--Performance Counter Report--\nTotal Time: %lld microseconds ",(alt_u64)total_usec);
printf ("(%llu clock-cycles)\n\n", total_clocks);
printf ("%s",separator);
printf ("%s",column_header);
for (section_num = 1; section_num <= 2; section_num++)
section_clocks = perf_get_section_time (perf_base, section_num);
if (section_num == 1){
printf ("|rate0 ");}
else {
printf ("|rate1 ");}
printf ("|%5lld",(section_clocks * 100) / total_clocks); // %
printf ("|%12lld",(section_clocks*1000000) / clock_freq_hertz); // time (us)
printf ("|%15lld",section_clocks); // time (clocks)
printf ("|%11u", (unsigned int) perf_get_num_starts (perf_base, section_num)); // occurrences
printf ("|\n");
return 0;
/* The example "main" function illustrates what is required by your
* application code to initialize, execute, and terminate the generated code.
* Attaching rt_OneStep to a real-time clock is target specific. This example
* illustates how you do this relative to initializing the model.
int main(int_T argc, const char_T *argv[])
/* Initialize model */
PERF_RESET(PERFORMANCE_COUNTER_0_BASE);
int_T count = 0;
FILE *model_out;
CALL MYFUNCTION1;
/* Attach rt_OneStep to a timer or interrupt service routine with
* period 0.0002 seconds (the model&#39;s base sample time) here. The
* call syntax for rt_OneStep is
* rt_OneStep(varipitch_M);
printf("Warning: The simulation will run forever. "
"Generated ERT main won&#39;t simulate model step behavior. "
"To change this behavior select the &#39;MAT-file logging&#39; option.\n");
fflush(NULL);
PERF_START_MEASURING(PERFORMANCE_COUNTER_0_BASE);
while(count < 1){
CALL MYFUNCTION2
PERF_BEGIN(PERFORMANCE_COUNTER_0_BASE, RATE0);
count++;
PERF_END(PERFORMANCE_COUNTER_0_BASE, RATE0);
PERF_STOP_MEASURING(PERFORMANCE_COUNTER_0_BASE);
perf_print_my_formatted_report((void*)PERFORMANCE_COUNTER_0_BASE, ALT_CPU_FREQ);
output capture from screen:
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems. You may experience intermittent JTAG communication
nios2-terminal: failures with this cable. Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable. Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Warning: The simulation will run forever. Generated ERT main won&#39;t simulate mode
l step behavior. To change this behavior select the &#39;MAT-file logging&#39; option.
I am loading
Total Time: 217020518514230016 microseconds (18446744073709551615 clock-cycles)
|rate0 | 0|217020518514| -1| 4294967295|
|rate1 | 0|217020518514| -1| 4294967295|
I generated the C code from matlab embedded real time workshop so that&#39;s why there are funky type like char_T, int_T, real32_T. Those are just regulare char, int, double but typedef in rtwtypes.h.
