problem with usb
名誉分销商 II
1,028 次查看
My uclinux kernel can't detect the usb disk,following is the boot message :
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6208k/8192k RAM, 0k/0k ROM (1495k kernel code, 395k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80800880 (irq = 1) is a jtag_uart
scsi_debug_init: out of memory, 1
SCSI Media Changer driver v0.25
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362_hc_reset:
Clock not ready after 20ms
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362-hcd isp1362-hcd: irq 3, io mem 0x808008c0
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd:  ISTL:    2 *  256:      512 @ $0000:$0100
isp1362-hcd isp1362-hcd:  INTL:  16 * ( 64+8):  1152 @ $0200
isp1362-hcd isp1362-hcd:  ATL :  32 * ( 64+8):  2304 @ $0680
isp1362-hcd isp1362-hcd:  USED/FREE:  3968      128
usb usb1: Product: ISP1362 Host Controller
usb usb1: Manufacturer: uClinux 2.6.16-uc0 isp1362-hcd
usb usb1: SerialNumber: isp1362-hcd
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 3
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbtest
NET: Registered protocol family 2
IP route cache hash table entries: 128 (order: -3, 512 bytes)
TCP established hash table entries: 512 (order: -1, 2048 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 256k freed (0x18a000 - 0x1c9000)
Shell invoked to run file: /etc/rc
Command: hostname uClinux
Command: mount -t proc proc /proc
Command: mount -t sysfs sysfs /sys
Command: mount -t usbfs none /proc/bus/usb
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: cat /etc/motd
Welcome to
          ____ _  _
        /  __| ||_|
    _  _| |  | | _ ____  _  _  _  _
  | | | | |  | || |  _ \| | | |\ \/ /
  | |_| | |__| || | | | | |_| |/
  |  ___\____|_||_|_| |_|\____|\_/\_/
  |_|
For further information check:
http://www.uclinux.org/ (http://www.uclinux.org/
Execution Finished, Exiting
Sash command shell (version 1.1.1)
/>[/b]
--- Quote End ---
Could anybody tell me where did i take a mistake?
Thank you!
0 项奖励
0 回复数
回复
