12748 Discussions
question about nios2 bin file
hi:
I use nios2 toolchains compile a ap from open source.Compile success and make
the bin file.
I copy the bin file to ~/rootfs/bin, and rebuild kernel . I download zImage to dvb
and exec , i execed the bin file,but fail.
the erro informatin: the bad ......file
I use nios2-linux-uclibc-flthdr ,nios2-linux-uclibc elf2flt cmd to exchanger the file
format.But failed.
How can I do?thanks a lot.
--- Quote Start ---
originally posted by alex824@May 8 2006, 01:02 PM
hi:
i use nios2 toolchains  compile a ap from open source.compile success and make
the bin file.
i copy the bin file to ~/rootfs/bin, and rebuild kernel . i download zimage to dvb
i use nios2-linux-uclibc-flthdr ,nios2-linux-uclibc  elf2flt cmd to exchanger the file
format.but failed.
how can i do?thanks a lot.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15178)
--- quote end ---
--- Quote End ---
You should add "-elf2flt" during objects linking.
It won&#39;t work if you use them on an elf.
If you didn&#39;t see the "CPIO" and "GZIP" in compile message, the initramfs is not updated. You will have to remove the file usr/initramfs_list in kernel dir, and compile again to force the update of initramfs.
