Hi hippo.
I did what you teach me on the internet. Thank you!! zImage ,as the result. When I download it into board, in the nios2-terminal , we see like : (please see 2.bmp) it always repeat displays from "Free pages:" to some place and never stop. Is there something wrong with the zImage. The board is stratix1s10. 2.bmp can be download at : http://forum.niosforum.com/forum/index.php?showtopic=3852 (http://forum.niosforum.com/forum/index.php?showtopic=3852)Link Copied
--- Quote Start --- originally posted by zzh@May 4 2006, 10:34 PM hi hippo.
i did what you teach me on the internet. thank you!!
zimage ,as the result. when i download it into board, in the nios2-terminal , we see like :
(please see 2.bmp)
it always repeat displays from "free pages:" to some place and never stop.
is there something wrong with the zimage.
the board is stratix1s10.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15047)
--- quote end ---
--- Quote End --- Sorry for late. I can not see your message in bmp. Please scroll to the beginning of boot message in the sdk shell window, cut and paste into the post.
I built a zImage for altera nios2 dev board 1s40 standard. please try out,
http://hungryhippo.jot.com/wikihome/zimage_std_1s10 (http://hungryhippo.jot.com/wikihome/zimage_std_1s10)- Mark as New
--- Quote Start --- originally posted by hippo@May 6 2006, 05:35 PM i built a zimage for altera nios2 dev board 1s40 standard. please try out,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15115)
--- quote end ---
--- Quote End --- Hi hippo, that link needs to sign in with user name and password !
--- Quote Start --- originally posted by mfm+may 8 2006, 05:09 am--><div class='quotetop'>quote (mfm @ may 8 2006, 05:09 am)</div>
--- quote start ---
<!--quotebegin-hippo@May 6 2006, 05:35 PM i built a zimage for altera nios2 dev board 1s40 standard. please try out,
--- quote end ---
--- Quote End --- Hi hippo, that link needs to sign in with user name and password ! <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15159)</div> [/b] --- Quote End --- Those links are update. Please check again.
TO_BE_DONE
my booting info as following :
/etc/issue www.microtronix.com June Uncompressing L
ux .... OK,booting the kernel.
Linux version 2.6.11-uc0 <melvin@zzhlinux> <gcc version 3.4.6>
uClinux/Nios II
Altera Nios II support <c> 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6444k/8192k RAM, 0k/0k ROM (1184k kernel code, 467k data)
Mount-cache hash table entries: 512
oom-killer:gfp_mask=0xd2
DMA per-cpu:
cpu 0 hot:low 2,high 6,batch 1
pu 0 cold:low 0,high 2,batch 1
Normal per-cpu:empty
HighMen per-cpu:empty
(start from next line)
Free pages: 0KB <okb HighMem)
Active :2335......
DMA free:..........
Normal free:........
--- Quote Start --- originally posted by zzh@May 8 2006, 05:00 PM
/etc/issue www.microtronix.com june uncompressing l
ux .... ok,booting the kernel.
linux version 2.6.11-uc0 <melvin@zzhlinux> <gcc version 3.4.6>
uclinux/nios ii
altera nios ii support <c> 2004 microtronix datacom ltd.
built 1 zonelists
kernel command line:
pid hash table entries: 128 (order: 7, 2048 bytes)
dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
memory available: 6444k/8192k ram, 0k/0k rom (1184k kernel code, 467k data)
mount-cache hash table entries: 512
dma per-cpu:
normal per-cpu:empty
highmen per-cpu:empty
free pages: 0kb <okb highmem)
active :2335......
dma free:..........
normal free:........
i can't copy the information ,i type it . maybe something is different with the booting information. but you can't see the some.
thank you ! hippo . you are a really a kind man. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
yes, the zimage you offered , i can't download . need username and password.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15184)</div> --- Quote End --- Please find the updated zImage links on another web site. http://forum.niosforum.com/forum/index.php?showtopic=3875 (http://forum.niosforum.com/forum/index.php?showtopic=3875) Did you use the minimal kernel config file ? cp ~/download/kernel.config ~/linux-2.6.x/.config And make ..... zImage again.
