nios2-terminal
As you can see in the follows pict, i would like to download the vmlinux in flash memory. But i&#39;ve this error message when i want launch the command. I don&#39;t know why... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Could you help me...?
http://c.beyls.free.fr/02.JPG
http://c.beyls.free.fr/01.JPG
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
http://c.beyls.free.fr/01.JPG [/b]
--- Quote End ---
hi,
I don&#39;t know but it can be the size of the images http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
can u give more details about the problem http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
hi,
now I understand, there is many ways to overcome this problem. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
the easiest is :
go to quartus programmer --> hardware setup
and disable all cables exept the one u use for download the .sof
for example if u have : ByteBlaster & MasterBlaster activetied then remove the MasterBlaster. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
hi,
another tip :
if u are using byteBlaster download cable u will have intermitant problem like "exiting due to I/O errors".
but u can do the following :
--> if your IP @ddress is still not configured so go to file system : /etc/rc and uncomment the line :# ifattch ... and configure the IP address
--> after configuring the device u can access the uClinux by telenet instead of nios2terminal : it&#39;s more fast
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
--- Quote Start ---
--- Quote End ---
PERFECT ! Thanks, I&#39;ve just download the kernel in the device.
Now, i&#39;ll study the continuation. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
sdhnain, do u speak french ?
--- Quote Start ---
originally posted by pairin20+may 7 2006, 09:23 pm--><div class='quotetop'>quote (pairin20 @ may 7 2006, 09:23 pm)</div>
--- quote start ---
<!--quotebegin-sdhnain@May 7 2006, 09:31 AM
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15158)</div>
[/b]
--- Quote End ---
salut,
oui bien sûr je parle français
