- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
As you can see in the follows pict, i would like to download the vmlinux in flash memory. But i've this error message when i want launch the command. I don't know why... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Could you help me...? http://c.beyls.free.fr/02.JPG http://c.beyls.free.fr/01.JPG링크가 복사됨
6 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
<div class='quotetop'>QUOTE </div>
--- Quote Start --- http://c.beyls.free.fr/02.JPG http://c.beyls.free.fr/01.JPG [/b] --- Quote End --- hi, I don't know but it can be the size of the images http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif can u give more details about the problem http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
hi,
now I understand, there is many ways to overcome this problem. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif the easiest is : go to quartus programmer --> hardware setup and disable all cables exept the one u use for download the .sof for example if u have : ByteBlaster & MasterBlaster activetied then remove the MasterBlaster. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
hi,
another tip : if u are using byteBlaster download cable u will have intermitant problem like "exiting due to I/O errors". but u can do the following : --> if your IP @ddress is still not configured so go to file system : /etc/rc and uncomment the line :# ifattch ... and configure the IP address --> after configuring the device u can access the uClinux by telenet instead of nios2terminal : it's more fast http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- originally posted by sdhnain@May 7 2006, 09:31 AM go to quartus programmer --> hardware setup
and disable all cables exept the one u use for download the .sof --- Quote End --- PERFECT ! Thanks, I've just download the kernel in the device. Now, i'll study the continuation. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif sdhnain, do u speak french ?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- originally posted by pairin20+may 7 2006, 09:23 pm--><div class='quotetop'>quote (pairin20 @ may 7 2006, 09:23 pm)</div>
--- quote start ---
<!--quotebegin-sdhnain@May 7 2006, 09:31 AM go to quartus programmer --> hardware setup
and disable all cables exept the one u use for download the .sof --- Quote End --- PERFECT ! Thanks, I've just download the kernel in the device. Now, i'll study the continuation. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif sdhnain, do u speak french ? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15158)</div> [/b] --- Quote End --- salut, oui bien sûr je parle français
