Is the zImage right
Hi hippo.
I did what you teach me on the internet. Thank you!!
zImage ,as the result. When I download it into board, in the nios2-terminal , we see like :
(please see 2.bmp)
it always repeat displays from "Free pages:" to some place and never stop.
Is there something wrong with the zImage.
The board is stratix1s10.
2.bmp can be download at :
http://forum.niosforum.com/forum/index.php?showtopic=3852 (http://forum.niosforum.com/forum/index.php?showtopic=3852)
--- Quote Start ---
originally posted by zzh@May 4 2006, 10:34 PM
hi hippo.
i did what you teach me on the internet. thank you!!
zimage ,as the result. when i download it into board, in the nios2-terminal , we see like :
(please see 2.bmp)
it always repeat displays from "free pages:" to some place and never stop.
is there something wrong with the zimage.
the board is stratix1s10.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15047)
--- quote end ---
--- Quote End ---
Sorry for late.
I can not see your message in bmp.
Please scroll to the beginning of boot message in the sdk shell window, cut and paste into the post.
I built a zImage for altera nios2 dev board 1s40 standard. please try out,
http://hungryhippo.jot.com/wikihome/zimage_std_1s10 (http://hungryhippo.jot.com/wikihome/zimage_std_1s10)
--- Quote Start ---
originally posted by hippo@May 6 2006, 05:35 PM
i built a zimage for  altera nios2 dev board 1s40 standard. please try out,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15115)
--- quote end ---
--- Quote End ---
Hi hippo,
that link needs to sign in with user name and password !
--- Quote Start ---
originally posted by mfm+may 8 2006, 05:09 am--><div class='quotetop'>quote (mfm @ may 8 2006, 05:09 am)</div>
--- quote start ---
<!--quotebegin-hippo@May 6 2006, 05:35 PM
--- quote end ---
--- Quote End ---
Hi hippo,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15159)</div>
[/b]
--- Quote End ---
Those links are update. Please check again.
TO_BE_DONE
my booting info as following : /etc/issue          www.microtronix.com       June Uncompressing L ux .... OK,booting the kernel. Linux version 2.6.11-uc0 <melvin@zzhlinux> <gcc version 3.4.6> uClinux/Nios II Altera Nios II support <c> 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 128 (order: 7, 2048 bytes) Dentry cache hash table entries: 4096 (order: 2, 16384 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6444k/8192k RAM, 0k/0k ROM (1184k kernel code, 467k data) Mount-cache hash table entries: 512 oom-killer:gfp_mask=0xd2 DMA per-cpu: cpu 0 hot:low 2,high 6,batch 1 pu 0 cold:low 0,high 2,batch 1 Normal per-cpu:empty HighMen per-cpu:empty (start from next line) Free pages:        0KB <okb HighMem)   Active :2335...... DMA free:.......... Normal free:........
I can&#39;t copy the information ,I type it . Maybe something is different with the booting information. but you can&#39;t see the some.
Thank you ! hippo . you are a really a kind man. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Yes, the zImage you offered , I can&#39;t download . need username and password.
--- Quote Start ---
originally posted by zzh@May 8 2006, 05:00 PM
my booting info as following : /etc/issue          www.microtronix.com       june uncompressing l ux .... ok,booting the kernel. linux version 2.6.11-uc0 <melvin@zzhlinux> <gcc version 3.4.6> uclinux/nios ii altera nios ii support <c> 2004 microtronix datacom ltd. built 1 zonelists kernel command line: pid hash table entries: 128 (order: 7, 2048 bytes) dentry cache hash table entries: 4096 (order: 2, 16384 bytes) inode-cache hash table entries: 1024 (order: 0, 4096 bytes) memory available: 6444k/8192k ram, 0k/0k rom (1184k kernel code, 467k data) mount-cache hash table entries: 512 oom-killer:gfp_mask=0xd2 dma per-cpu: cpu 0 hot:low 2,high 6,batch 1 pu 0 cold:low 0,high 2,batch 1 normal per-cpu:empty highmen per-cpu:empty (start from next line) free pages:        0kb <okb highmem)   active :2335...... dma free:.......... normal free:........
i can&#39;t copy the information ,i type it . maybe something is different with the booting information. but you can&#39;t see the some.
thank you ! hippo . you are a really a kind man. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
yes, the zimage you offered , i can&#39;t download . need username and password.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15184)</div>
--- Quote End ---
Please find the updated zImage links on another web site.
http://forum.niosforum.com/forum/index.php?showtopic=3875 (http://forum.niosforum.com/forum/index.php?showtopic=3875
Did you use the minimal kernel config file ?
cp ~/download/kernel.config ~/linux-2.6.x/.config
And make ..... zImage again.
