i have compiled uclinux kernel and tried to run it on DE1(on the sdram)
first i got crc error and i fixed it but now when finally i see: "uncomressing linux...booting the kernel" it just stack like this... help please!!:confused: thank's:)Link Copied
What is the size of zImage file ?
1.3MB more or less...
Could you tell us a little bit more :
Do you use Linux / uClinux ? Does the TryOutuClinux work on your dev board ?- Mark as New
I use uClinux..
The TryOutuClinux works till the command: nios2-terminal then i get: "uncompressing linux...booting the kernel" and it freezed like that! thank's for your help!!!:)- Mark as New
--- Quote Start --- i have compiled uclinux kernel and tried to run it on DE1(on the sdram) first i got crc error and i fixed it but now when finally i see: "uncomressing linux...booting the kernel" it just stack like this... help please!!:confused: thank's:) --- Quote End --- I got the same CRC error, how you fixed it? thank's.
Topic Options
