12746 Discussions
"uncompressing linux...booting the kernel"
i have compiled uclinux kernel and tried to run it on DE1(on the sdram)
first i got crc error and i fixed it but now when finally i see:
"uncomressing linux...booting the kernel"
it just stack like this...
help please!!:confused:
thank's:)
What is the size of zImage file ?
1.3MB more or less...
Could you tell us a little bit more :
Do you use Linux / uClinux ? Does the TryOutuClinux work on your dev board ?
I use uClinux..
The TryOutuClinux works till the command: nios2-terminal
then i get: "uncompressing linux...booting the kernel"
and it freezed like that!
thank's for your help!!!:)
--- Quote Start ---
thank's:)
--- Quote End ---
I got the same CRC error, how you fixed it?
thank's.
