re-compile problem
dear all,
when i finish the make linux Image and download it to the target board successfully .I want to reconfig kernal ,when re-run "make menuconfig" command
then the following information emerged:
/home/wangzhiwunpu/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/Makefile:698: warning: overriding commands for target `arch/nios2nommu/kernel/vmlinux.lds.S'
/home/wangzhiwunpu/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/Makefile:519: warning: ignoring old commands for target `arch/nios2nommu/kernel/vmlinux.lds.S'
/home/wangzhiwunpu/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/Makefile:702: warning: overriding commands for target `linuxsrec'
/home/wangzhiwunpu/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/Makefile:523: warning: ignoring old commands for target `linuxsrec'
/home/wangzhiwunpu/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/Makefile:707: warning: overriding commands for target `zImage'
/home/wangzhiwunpu/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/Makefile:528: warning: ignoring old commands for target `zImage'
scripts/kconfig/mconf arch/nios2nommu/Kconfig
file init/Kconfig already scanned?
make[3]: *** [menuconfig] Error 1
make[2]: *** [menuconfig] Error 2
make[2]: Leaving directory `/home/wangzhiwunpu/uClinux-dist-test/linux-2.6.x'
make[1]: *** [linux_menuconfig] Error 2
make[1]: Leaving directory `/home/wangzhiwunpu/uClinux-dist-test'
make: *** [menuconfig] Error 2
[wangzhiwunpu@localhost uClinux-dist-test]$
It looks like the Nios2 Makefile was patched multiple times.
You should do the nios2 patch only once.
Try rename the old uCLinux-dist-test tree, and create a new one .
Then compare what is changed in Nios2 Makefile.
If you want to config kernel, you should be in ~/uCLinux-dist-test dir, and
make menuconfig
Kernel/Library/Defaults Selection --->
(linux-2.6.x) Kernel Version
(None) Libc Version
[ ] Default all settings (lose changes)
[*] Customize Kernel Settings
[ ] Customize Vendor/User Settings
[ ] Update Default Vendor Settings
Then <exit> <exit> <yes> .
It will enter kernel config.
And after you finish kernel config,
make linux image
