12748 Discussions
Can't access the Main function!
Hi community:
Now i encounter a really strange problem.
I develop a nios system. It contains SDram, Sram, Flash, and other module. There is no error while i compile it in SOPC and Quartus.
When i start a Hello LED project in NIOS IDE, the Alt_main is the entry of the program, everything goes well. No matter i Debug this program in both of the Ram(Sram, SDram) , or i download the .elf to the FLASH and let the program start from FLASH, the LED program runs pretty well.
BUT, when i start a new project HELLO WORLD, the main is the entry , trouble comes out!! (This HELLO WORLD project can only print a string "HELLO" using the stdout. )
The compile process finishes without any error. But after i press the DEBUG button, the program seems keeping "running" without stop in the Main function. And the "Step into, Step over, Step run" icon is gray that can't be pressed.
I just wonder where is the current PC. So i press the "Suspend" button. The PC jump between alt_irq.h and alt_irq_handler.c over and over.
In detail, the PC always jump from this section below in alt_irq.h
static ALT_INLINE alt_u32 ALT_ALWAYS_INLINE alt_irq_pending (void)
alt_u32 active;
NIOS2_READ_IPENDING (active);
return active;
to this section below in alt_irq_hander.c
void alt_irq_handler (void)
alt_u32 active;
alt_u32 mask;
alt_u32 i;
* Notify the operating system that we are at interrupt level.
ALT_OS_INT_ENTER();
* Obtain from the interrupt controller a bit list of pending interrupts,
* and then process the highest priority interrupt. This process loops,
* loading the active interrupt list on each pass until alt_irq_pending()
* return zero.
* The maximum interrupt latency for the highest priority interrupt is
* reduced by finding out which interrupts are pending as late as possible.
* Consider the case where the high priority interupt is asserted during
* the interrupt entry sequence for a lower priority interrupt to see why
* this is the case.
active = alt_irq_pending ();
do
i = 0;
mask = 1;
* Test each bit in turn looking for an active interrupt. Once one is
* found, the interrupt handler asigned by a call to alt_irq_register() is
* called to clear the interrupt condition.
do
if (active & mask)
alt_irq.handler(alt_irq.context, i);
break;
mask <<= 1;
i++;
} while (1);
} while (active);
* Notify the operating system that interrupt processing is complete.
ALT_OS_INT_EXIT();
and once go over the if(active & mask) in loop
do
if (active & mask)
break;
mask <<= 1;
i++;
} while (1);
the next time will go into the if(active & mask) and break.
and now the pc return to the section i mentioned first time in alt_irq.h
alt_u32 active;
return active;
So, here comes out a infinite loop. And the program will never go to the Main() function.
Why? And how to fix it?
I would like to offer some information further more.
1). The SDRAM, SRAM, FLASH works! Because in the HELLO_LED program, i let the program located in the SDRAM, SRAM and the program can run.
2). This situation is not all along. I mean the HELLO_WORLD program did work in the first time i debug it. But from i debug it in the next day till now, it is dead.
Please give me some advice, or solution.
I will reply the information you needed as soon as possible.
Thanks all of U. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Kevin.Lee
It is enough to have an exercise with hello .
Then you should jump start on uClinux.
http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux
There is no need to spend much time on HAL API.
Hippo&#39;s right, if uCLinux is what you&#39;d like run, eventually. Since you didn&#39;t post this to the uCLinux Forum, I&#39;m assuming that you don&#39;t want to run uCLinux. So, here are my questions:
Which interrupt is causing this problem? Also, does the initialization code, for your devices, function? (Hint: step through the code in alt_sys_init.c)
You mentioned that you had it working, at one point. What have you changed?
Best of luck,
- slacker
