- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
hello
im compiling the "hello world" example using a hardware design with 32k Byte memory on chip and Im getting these errors that can't be solved.. !! any ideas? Description Resource Path Location Type make: *** [serial1.elf] Error 1 serial1 0 C/C++ Problem region onchip_memory2_0 is full (serial1.elf section .text). Region needs to be 16292 bytes larger. serial1 0 C/C++ Problem section .bss [0000a004 -> 0000a217] overlaps section .text [000081c4 -> 00013fa3] serial1 0 C/C++ Problem section .rodata [00008020 -> 00008513] overlaps section .exceptions [00008020 -> 000081c3] serial1 0 C/C++ Problem section .rwdata [00008514 -> 0000a003] overlaps section .text [000081c4 -> 00013fa3] serial1 0 C/C++ Problem waiting your replies thanks링크가 복사됨
3 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi
Error is because you overlapped the boot address and exception address Try Changing the exception address to some other memory regards M Kalyansrinivas- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The regular Hello World example will not fit in 32k. You'll have to use the unhosted version (Hello World Small).
Jake
