12748 Discussions
region on chip memory is full error .. plz help
hello
im compiling the "hello world" example
using a hardware design with 32k Byte memory on chip
and Im getting these errors that can't be solved.. !!
any ideas?
Description Resource Path Location Type
make: *** [serial1.elf] Error 1 serial1 0 C/C++ Problem
region onchip_memory2_0 is full (serial1.elf section .text). Region needs to be 16292 bytes larger. serial1 0 C/C++ Problem
section .bss [0000a004 -> 0000a217] overlaps section .text [000081c4 -> 00013fa3] serial1 0 C/C++ Problem
section .rodata [00008020 -> 00008513] overlaps section .exceptions [00008020 -> 000081c3] serial1 0 C/C++ Problem
section .rwdata [00008514 -> 0000a003] overlaps section .text [000081c4 -> 00013fa3] serial1 0 C/C++ Problem
waiting your replies
thanks
Try compiling the Hello World Small example.
Hi
Error is because you overlapped the boot address and exception address Try Changing the exception address to some other memory
regards
M Kalyansrinivas
The regular Hello World example will not fit in 32k. You'll have to use the unhosted version (Hello World Small).
Jake
