remap section .exception
Hi guys,
I would like to map the .exceptions section to a location in memory different to the location specified in the autogenerated linker script or exclude it at all from the elf file.
The linker flag --section-start=.exceptions=0x1100000 has been ignored by the IDE.
Is there any other way to move this section or an option to tell the linker to ignore it?
thanks for any help!
--Wolf
--- Quote Start ---
originally posted by pfab@Dec 22 2005, 10:39 AM
hi guys,
i would like to map the .exceptions section to a location in memory different to the location specified in the autogenerated linker script or exclude it at all from the elf file.
the linker flag --section-start=.exceptions=0x1100000 has been ignored by the ide.
is there any other way to move this section or an option to tell the linker to ignore it?
--wolf
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11741)
--- quote end ---
--- Quote End ---
In the SOPC builder under "More cpu settings" you can change the exception address, which will change where the exceptions section is located. I think that&#39;ll probably change where everything else is located too though.
Also if you want to pass options to the linker you need to use the -Wl option. For instance, I have one of my projects configured to generate a map file when it builds. So in the C/C++ Build section, I have the string "-Wl,-Map -Wl,app.map" in the Linker Flags box. Maybe that&#39;s why the IDE is ignoring your --section-start option?
Finally you can use a customized linker script by going into your system library properties and choosing "Custom linker script". I think most people make a copy of the generated.x file, name it something else, and then modify it according to their needs. I&#39;m not too familiar with the syntax there, but if you search for "generated.x" or "linker" I&#39;m sure you&#39;ll find some threads with instructions on how to modify it.
