requsting interrupt fails
I have an UL with one interrupt. When I try to request the interrupt, it fails. Here is the code of my driver:
static int __init mod_init(void) {     u8 errorcode;     printk("DSP: Driver loaded\n");     if( register_chrdev(240, "DSPDriver", &fops) == 0) {  printk("DSP: registering device\n");  if( request_irq(IRQ_NR, driver_isr, SA_INTERRUPT|SA_SHIRQ, "dsp", &fops))  {      printk("DSP: Got IRQ %i\n", IRQ_NR);      return 0;  }  else  {      printk("DSP: ERROR IRQ request failed!\n");            unregister_chrdev(240, "DSPDriver");      return -EBUSY;  }     }     printk("DSP: registering device FAILED\n");     return -EIO; } static void __exit mod_exit(void) {     printk("cleanup_module called\n");     free_irq( IRQ_NR, &fops );     unregister_chrdev(240, "DSPDriver"); } module_init( mod_init ); module_exit( mod_exit );
I don't know why. My driver should be the only one requesting this IRQ. It doesn't matter if I request it shared or exclusively.
/proc/interrupts looks like this:
# cat /proc/interrupts  1:        519   jtag_uart  3:      90384 L timer  6:        270   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90386 L timer  6:        270   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90394 L timer  6:        274   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90407 L timer  6:        298   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90420 L timer  6:        330   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90432 L timer  6:        330   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90446 L timer  6:        377   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90458 L timer  6:        383   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90471 L timer  6:        403   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90484 L timer  6:        421   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90497 L timer  6:        455   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90511 L timer  6:        527   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90516 L timer  6:        527   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90527 L timer  6:        535   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90531 L timer  6:        535   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90533 L timer  6:        535   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90534 L timer  6:        538   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90535 L timer  6:        538   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90536 L timer  6:        538   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90550 L timer  6:        571   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90553 L timer  6:        571   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90554 L timer  6:        571   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90555 L timer  6:        571   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90556 L timer  6:        571   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90567 L timer  6:        579   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90570 L timer  6:        579   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90571 L timer  6:        580   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90572 L timer  6:        580   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90573 L timer  6:        580   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90575 L timer  6:        580   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90576 L timer  6:        580   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90583 L timer  6:        609   eth0  8:          0   dsp   :          0   spurious  1:        519   jtag_uart  3:      90589 L timer  6:        625   eth0  8:          0   dsp   :          0   spurious
Based on /proc/interrupts, request_irq() did not fail and
assigned you interrupt number 8.
--Scott
But why do I always get
DSP: Driver loaded DSP: registering device DSP: ERROR IRQ request failed!
when I load the driver?
Hi MRKs,
The value returned from request_irq() is either 0 to indicate success
or a negative error code ... just test for zero & you should be fine:
if( request_irq(IRQ_NR, driver_isr, SA_INTERRUPT|SA_SHIRQ, "dsp", &fops) == 0)
or test for zero
--Scott
You've been right. Thank you!
