run from onchip ROM
Hi, everyone!
I'm testing NIOS in custom board.
Using SOPC builder, my system composed of CPU, onchip-ROM(instruction), onchip-ram(data) and PIO(led).
After compile those system in IDE, onchip-rom's hexa file was generated automatily.
I knew another mehod that is coverting elf to hex. (nios2-elf-objcopy)
Using those methods, results are mismatched.
What is right between automatic generated hex and nios2-elf-objcopy program?
Thanks and regards!!
Using a generated hex, NIOS operated well in custom board.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
