12748 Discussions
using PIOs to communicate with an LCD controller
Hi everyone. Karthik here.
I am using an LCD controller to communicate with the optrex lcd module and i want to send the data to the controller from the nios processor thru pios. can anyone tell me where i can find information about the macros defined in the altera_avalon_pio_regs.h header file. i am using the following code to do this but im not getting any transitions on the pios (on the scope)
# include "stdio.h"# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"
int main (void)
alt_u8 data[15]={0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x50,0x51,0x52,0x53,0x54,
0x55};
alt_u8 reset;
alt_u8 we;
volatile int ack;
volatile int i;
reset = 1;
do
ack = IORD_ALTERA_AVALON_PIO_DATA(LCD_ACK_PIO_BASE);
}while (!(ack));
we=1;
while(1)
for(i=0;i<16;i++)
IOWR_ALTERA_AVALON_PIO_DATA(LCD_DATA_PIO_BASE,data[i]);
while (!(ack));
i=0;
return (0) ;
May i ask what reason do you have for not including the Optrex IP via SOPC? Wouldnt that be alot easier?
--- Quote Start ---
originally posted by tembridis@Mar 26 2007, 07:09 PM
may i ask what reason do you have for not including the optrex ip via sopc? wouldnt that be alot easier?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22513)
--- quote end ---
--- Quote End ---
Thanks a lot for ur reply.
I was trying to interface the lcd through a controller because i wanted to verify the working of the LCD Controller (designed by me). And i had made some errors in the code. I got rid of them and my controller seems to be working fine.
Thanks a lot again.
Karthik
