12748 Discussions
running application on linux system on eval board
I have difficulty in running the application on nios2 system.
The process followed is:
> Built application project hell with c file hello.c
> the generated .exe - hello.exe added to filesystem project created earlier - hello.exe copied to
target/bin folder of filesystem project
> Filesystem project built again
> Filesystem proj uploaded
Now, my kernel proj(done earlier) and filesystem proj are
uploaded (i.e. they are into Flash- which location?)
Now to runthis perticular hello.exe what I am supposed to do.
*Am I supposed to download the .sof for this linux_1c20 system and then how the hello.exe will run.
After conf FPGA with the .sof 7 seg LED display counter and some pattern runs on LEDs
My concern is how to run this .exe in filesystem
Please guide on this
Thanks and Regards
Hi
All you do is browse to the directory where the hallo.exe file is located and type# ./hallo.exe
this should run the program.
From other location ,assuming the hallo.exe is in the /bin directory type# ./bin/hallo.exe (I think)
Good luck
Rual
--- Quote Start ---
originally posted by rual@Oct 26 2005, 07:51 PM
hi
all you do is browse to the directory where the hallo.exe file is located and type# ./hallo.exe
from other location ,assuming the hallo.exe is in the /bin directory type# ./bin/hallo.exe  (i think)
good luck
rual
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10599)
--- quote end ---
--- Quote End ---
I think I need to do this from nios2 terminal
but when I am giving nios2-terminal
then user name as nios and password as uClinux as mentioned in reference guide
its giving incorrect login
Pl clarify: FPGA should be configured with .sof?
Thanks and Regards
--- Quote Start ---
originally posted by rau+oct 26 2005, 07:56 pm--><div class='quotetop'>quote (rau @ oct 26 2005, 07:56 pm)</div>
--- quote start ---
<!--quotebegin-rual@Oct 26 2005, 07:51 PM
hi
good luck
rual
--- quote end ---
--- Quote End ---
Ok able to do it
Thanks every body
Thanks Rual
Thanks and Regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10600)</div>
[/b]
--- Quote End ---
