I defined an internal ROM with 16kBytes (0x00c08000-0x00c0bfff) and an internal RAM with 2kBytes starting at address 0x00c02000. Small C library and Reduced Device Drviers are used. When compiling the design the linker puts out the following error: section .text [00c08000 -> 00c09223] overlaps section .entry [00c08000 -> 00c0801f] In my opinion there is enough space left in the internal ROM, because the software seems to use only from ..8000 to ..9223. Why can't the linker separate the .text section from the .entry section!?!??!? Any ideas or hints!?!??! Thanks damcLink Copied
hi demc,
did you check the autogenerated linker script generated.x in ...syslib\debug\system_description\ for more information about memory assignments? --wolf- Mark as New
You can also add following options to your project setting under C/C++ build -> Linker ->General
-Xlinker -Map -Xlinker map.txt This will produce a detailed map file in same directory with your .elf file so you can take a closer look where your data and code is located.- Mark as New
Hello pfab,
the generated.x file looked ok for me ... Hello keijo, in the map.txt file it looks really like that the section .text and .entry start both at the same address 0x00c08000. So they overlap ;-(, the linker was right. I just changed the internal ROM address to 0x00000000 and ... it worked, no overlapping anymore. Section .entry starts now at 0x00000000 and section .text starts at 0x00000020. Remains the question, is it working now because I regenerated and recompiled everything or because I changed the ROM address (and it's a bug) .... So thanks for your hints and help!!! damc- Mark as New
What did you specify as reset and exception addresses in SOPC builder? There should be 0x20 offset in the exception address. If you did have the offset then my suggestion is that regeneration cured your problem.
As reset address I specified the internal ROM, as exception address the internal RAM.
In both of my versions. Sorry, I didn't checked the offset, the SOPC-Builder has done this automatically and also correct in the past...
