12747 Discussions
the question of the starting of uclinux by u-boot
when i download the kernel and filesystem of uclinux to the flash 0x0 ,
uclinux can rightly startup. but, when i use the u-boot to startup the
kernel and filesystem of uclinux by the bootm command, the program is
always running the half to stop.
follows:
U-Boot 1.1.3 (Dec 28 2005 - 19:11:13)
CPU : Nios-II
SYSID : d4a9fbb0, Mon Dec 19 06:36:32 2005
BOARD : Altera EP-1C6
*** Warning - bad CRC, using default environment
==> bootm 0x00040000# # Booting image at 00040000 ...
Image Name: 2.6.4 kernel for EP1C6
Image Type: Nios-II Linux Kernel Image (gzip compressed)
Data Size: 459971 Bytes = 449.2 kB
Load Address: 00800000
Entry Point: 00800000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
my u-boot is downloaded the address of 0x00000000;the kernel of uclinux
is downloaded the address of 0x00040000;the filesystem of uclinux is
downloaded the address of 0x00150000.
my load address is 0x00800000;my entry address is 0x00800000.(0x00800000
is my sdram the base address.)
why? can someone help me!
thanks!
