u-boot multi image
Has anyone successfully used a u-boot Multi image to boot into Linux?
I have zImage, initrd, and dtb that I want put into the image. My attempts so far have always resulted in:
SOCFPGA_CYCLONE5# fatload mmc 0 0x2000000 zzzmultiimage
reading zzzmultiimage
31098855 bytes read in 2718 ms (10.9 MiB/s)
SOCFPGA_CYCLONE5# bootm 0x2000000
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Multi image
Image Type: ARM Linux Multi-File Image (gzip compressed)
Data Size: 31098791 Bytes = 29.7 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 3407918 Bytes = 3.3 MiB
Image 1: 27671672 Bytes = 26.4 MiB
Image 2: 19183 Bytes = 18.7 KiB
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x03da3cf8
Uncompressing Multi-File Image ... Error: Bad gzipped data
GUNZIP: uncompress, out-of-mem or overwrite error - must RESET board to recover
resetting ..
I have tried a range of load addresses (0x2000000 pictured above), all get the same message.
I build the multi-image on the workstation using:
mkimage -A arm -O linux -T multi -a 0x8000 -e 0x8000 -C gzip -n 'Multi image' -d uImage:uRamdiskExt3ARM:socfpga_cyclone5_sockit.dtb zzzMultiImage
The .dtb comes straight from the kernel build.
For the uImage I have tried:
  • using the zImage straight from the kernel build,
  • the zImage wrapped by mkimage with:
mkimage -A arm -O linux -T kernel -C none -a 0x80008000 -e 0x80008000 -n "Linux kernel" -d zImage uImage
  • the Image straight from the kernel build, compressed with gzip -9, and then wrapped by mkimage with:
mkimage -n 'Linux' -A arm -O linux -T kernel -C gzip -a 0x80008000 -e 0x80008000 -d Image.gz uImage
The uRamdisk is a compressed ext3, wrapped by mkimage with:
mkimage -n "ModulesAdded,Compressed" -A arm -O linux -T ramdisk -C gzip -d rootfs.ext3.gz uRamdiskExt3ARM
If I use the components separately (zImage, uRamdiskExt3ARM, sockit.dtb) along with bootz, then all boots fine.
If anyone has gotten multi-image to work, please give me hint or some details about what you did to get it working.
Thanks!!!
--George Broz
Moog Industrial Group
Solution for anyone else down this path:
None of the components inside the multi-image are wrapped with mkImage.
* The Linux kernel image is just the plain 'Image' generated by the kernel build, zipped with gzip -v9 Image.
* The initrd is just a plain ol' ext3.gz
* The dtb is also that generated by the kernel build.
Put them together with:
mkimage -A arm -O linux -T multi -a 0x8000 -e 0x8000 -C gzip -n 'Multi image: kernel, initrd, dtb' -d Image.gz:rootfs.ext3.gz:socfpga_cyclone5_sockit.dtb mxImage
And to boot this on the target:
# fatload mmc 0 0x2000000 mxImage
# env set initrd_high 20000000
# env set bootargs console=ttyS0,115200 root=/dev/ram rw rootwait ramdisk_size=262144
# bootm 0x2000000
and you are off and running....
Environment size: 2124/4092 bytes
# # Booting kernel from Legacy Image at 02000000 ...
Data Size: 31098663 Bytes = 29.7 MiB
Contents:
Image 0: 3407854 Bytes = 3.2 MiB
Image 1: 27671608 Bytes = 26.4 MiB
# # Loading init Ramdisk from multi component Legacy Image at 02000000 ...
# # Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x03da3c78
Uncompressing Multi-File Image ... OK
reserving fdt memory region: addr=0 size=1000
Loading Ramdisk to 1e59c000, end 1ffffc38 ... OK
Loading Device Tree to 03ff8000, end 03fffaee ... OK
Starting kernel ... <snip>
Have fun!
--George
