12748 Discussions
uC/OS-II Stack Size always at maximum defined
I need help in understanding what could be the cause of the phenomena I see.
I have a webserver application (started from the altera example) to which I added a couple of other threads
- Database - a thread polling a large number of periphery components (i2c, Avalon-MM) and updates the latest value in a global array
- Http - accepts connections, fetches files from ZipFS, parses them and replaces certain strings with the values from the large array
- watchdog, etc...
- terminal --> I have also implemented a stack checking command.
Scenario:
  1. application up, no link -> Http not started; DATABASE uses ~4KB of stack
  2. http started, 1st request -> Database uses maximum defined.
Interesting, if I allocate 64KB or 4MB (which it uses completely), the application is stable in both cases, no difference.
The whole application uses ~ 1MB, so the I can't explain how it reaches those numbers...
My questions:
  1. What could be the reason the OSStatChk is reporting me these numbers?
  2. From my observation, this numbers returned by OSStatChk are the maximum ever used since startup. Is there a way to reset these counters?
********************************************************* *** OS_TASK *** used free ********************************************************* HTTP_TASK 28356 37180 TERMINAL_TASK 3776 4416 DATABASE_TASK 262144 0 PHYMON_TASK 3968 4224 WATCHDOG_TASK 3812 4380 TELNET_TASK 5996 10388
Moving to the new "Other Operating Systems" forum. This is where all non-Linux OS related questions will go moving forward.
