uClinux build problem
I am a newer of uCLinux.And I am trying to compile the uClinux and port it on the NiosII of DE2 Board.
when I run ../build in command line as step posted on this forum,
and error occured as follows:
__________________________________________________ ________________
<attachment>
Is someone can help me out?
It&#39;s strongly appreciate!
Then when I test the command:
[giantice@localhost download]$ nios2-linux-uclibc-gcc -v
bash: nios2-linux-uclibc-gcc: command not found
Does that mean the nios-cross environment is not build up?
