12745 Discussions
uClinux-dist-20070130 build error
I follow the UClinuxDist's step to build uClinux.
but alaways happen
"Can't run cmd gzip -f -9"
make menuconfig
make vendor_hwselect SYSPTF=~/hwprj/nios_0.prf
make romfs
make
Stop here, error alaways happen
[ ! -d "boa" ] || ( touch boa/.sgbuilt_user && make -j1 -C boa ) || exit $?
make[3]: Entering directory `/home/green/dev/nios2/uClinux-dist-20070130/uClinux -dist/user/boa'
for i in src ; do make -C $i all || exit ; done
make[4]: Entering directory `/home/green/dev/nios2/uClinux-dist-20070130/uClinux -dist/user/boa/src'
ucfront-gcc nios2-linux-uclibc-gcc -O2 -g -Dlinux -D__linux__ -Dunix -D__uClin ux__ -DEMBED -I/home/green/dev/nios2/uClinux-dist-20070130/uClinux-dist -I/home/ green/dev/nios2/uClinux-dist-20070130/uClinux-dist/include -fno-builtin -Dfork=v fork -D__adjtimex=adjtimex -Wl,-d -Wl,-elf2flt -o boa alias.o auth.o boa.o cgi.o cgi_header.o config.o get.o hash.o globals.o log.o nls.o pipe.o queue.o read.o request.o response.o signals.o timestamp.o util.o -lcrypt
request.o(.text+0x994): In function `process_header_end':
/home/green/dev/nios2/uClinux-dist-20070130/uClinux-dist/user/boa/src/request.c: 560: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
Can't run cmd gzip -f -9 >> boa
collect2: ld returned 4 exit status
make[4]: *** [boa] Error 1
make[4]: Leaving directory `/home/green/dev/nios2/uClinux-dist-20070130/uClinux- dist/user/boa/src'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/home/green/dev/nios2/uClinux-dist-20070130/uClinux- dist/user/boa'
make[2]: *** [boa] Error 2
make[2]: Leaving directory `/home/green/dev/nios2/uClinux-dist-20070130/uClinux- dist/user'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/green/dev/nios2/uClinux-dist-20070130/uClinux- dist/user'
make: *** [subdirs] Error 1
Since we use compressed flat format, you will need to update the binary tools. It fixed a bug in elf2flt.
--- Quote Start ---
originally posted by hippo@Feb 14 2007, 11:21 AM
since we use compressed flat format, you will need to update the binary tools. it fixed a bug in elf2flt.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21535)
--- quote end ---
--- Quote End ---
You mean that I need to reinstal newest nios2gcc.tar.bz2?
thx hippo
yes.
hello,G.R.green
I have the same question,did you resolve the question,please tell me?I use ubuntu 9.10,thank you!
