uart interrupt
hi !
i'm trying to use interrupt in NIOS II ide for the uart.
Are two days that i study this problem .
I saw sw development and reference handbooks , and found different informations about uart core and hal api functions , and also read a lot of
driver devices and .h files .
I found also an example writing by Kira and use it for my case
the code is :
# include "count_binary.h"
volatile int t;
volatile int uart_0;
static void handle_uart_interrupt(void* context,alt_u32 id)
t++;
IOWR_ALTERA_AVALON_PIO_DATA(PM_OUT_BASE, t);
int main(void)
IOWR_ALTERA_AVALON_UART_CONTROL(UART_0_BASE, 0x180);
alt_irq_register(UART_0_IRQ,&uart_0,handle_uart_interrupt);
while( 1 )
return(0);
but not run .On my development board i can see the led switch on when
a caracter arrive , but the interrupt doesn't work
Somebody know if i forget something else ?
thanks
ciao
walter
is it possible that your interrupt service routine does not clear the interrupt? may be, you can try to write zero to the status register?!
thanks
i resolved the problem and post the code
to help if somedoby need something
ciao
--- Quote Start ---
originally posted by pmicro@Mar 23 2006, 07:41 AM
thanks
ciao
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13719)
--- quote end ---
--- Quote End ---
Hi
Can you post the correct code?
PS: Are you italian?
