12748 Discussions
undefined reference to '__ctype_b'
hi,
Has any body ever encountered the problem of "undefined reference to __ctype_b" when linking with NIOS IDE before?
I got the following error while linking using nios-elf g++
Note: the reason why it's reporting __ctype_b_loc instead of __ctype_b is because I went into Microtronix uCLinux include directory, and changed all ctype_b to ctype_b_loc in ctype.h as suggested by this: http://www.molpro.net/molpro-user/archive/all/msg01417.html (http://www.molpro.net/molpro-user/archive/all/msg01417.html
I also tried using a bigger libc.a as well (which was not in microtronix uCLibc directory), but it didnt help.
Any help would be greatly appreciated! Thanks!
ERROR MESSAGE:
Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer (at 0x000a95e0) because the offset (-693728) is out of the allowed range, -32678 to 32767.[Debug/libAutoClip.a(clp_obj.o)(.text+0xa4):../../../../C_RT/Source/clp_obj.c]
undefined reference to `__ctype_b_loc'[../../../../C_RT/Source/clp_obj.c]
*169: undefined reference to `__ctype_b_loc' ../../../../C_RT/Source/clp_obj.c:169: Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer (at 0x000a95e0) because the offset (-693728) is out of the allowed range, -32678 to 32767. libAutoClip.a
FROM CONSOLE:
nios2-elf-g++ -nostdinc -D__linux__ -O0 -g -I"c:/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/c/altera/kits/nios2_51/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -I Connective_Logic_Systems/CLIP/BSP/Posix/Include -I Connective_Logic_Systems/CLIP/C_RT/Include -I Connective_Logic_Systems/CLIP/CPP_RT/Include -I Connective_Logic_Systems/CLIP/Operating_System/Posix/Include -I Connective_Logic_Systems/CLIP/Protocol/TCP_for_Posix/Include -I FFTW/fftw/Include -I PROSAS_Source/DataClasses/Include -I PROSAS_Source/Harnesses/Include -I PROSAS_Source/Infrastructure/Circuits/Include -I PROSAS_Source/Infrastructure/CxnPrototypes/Include -I PROSAS_Source/InputOutput/Devices/Include -I PROSAS_Source/Interfaces/Include/ -I PROSAS_Source/Processing/Include/ -I PROSAS_Source/ProjectHeaders/Include -I PROSAS_Source/Topics/ClpConfigDev -I PROSAS_Source/Topics/ClpList -D_DEBUG -c PROSAS_Source/InputOutput/Devices/Source/WatchDogDev.cpp -o Debug/WatchDogDev.o
nios2-elf-g++ Debug/ProcAFEstData.o Debug/ProcAzFftData.o Debug/ProcAzIFftData.o Debug/ProcAzMocompData.o Debug/ProcData.o Debug/ProcInputData.o Debug/ProcOutputData.o Debug/ProcRgMocompData.o Debug/ProcRmaData.o Debug/ProcRpAdjData.o Debug/ProcTRData.o Debug/ProSASData.o Debug/ProcAFEstAdjCellMthd.o Debug/ProcAFEstAFLineMthd.o Debug/ProcAFEstCellProcessMthd.o Debug/ProcAFEstFFTMthd.o Debug/ProcAFEstIFFTMthd.o Debug/ProcAFEstPointMthd.o Debug/ProcAFEstRMAMthd.o Debug/ProcAFEstSetupMthd.o Debug/ProcAzFftAzFftMthd.o Debug/ProcAzFftCopyBackMthd.o Debug/ProcAzFftSetupMthd.o Debug/ProcAzIFftAzIFftMthd.o Debug/ProcAzIFftCopyBackMthd.o Debug/ProcAzIFftSetupMthd.o Debug/ProcAzMocompAzMocompMthd.o Debug/ProcAzMocompCopyBackMthd.o Debug/ProcAzMocompSetupMthd.o Debug/ProcInputFepRxThrd.o Debug/ProcInputReadThrd.o Debug/ProcOutputWriteThrd.o Debug/ProcRgMocompCopyBackMthd.o Debug/ProcRgMocompRgMocompMthd.o Debug/ProcRgMocompSetupMthd.o Debug/ProcRmaCopyBackMthd.o Debug/ProcRmaRmaMthd.o Debug/ProcRmaSetupMthd.o Debug/ProcRpAdjcopyBackMthd.o Debug/ProcRpAdjRpAdjMthd.o Debug/ProcRpAdjSetupMthd.o Debug/ProcTRTRMthd.o Debug/ProcAFEstCct.o Debug/ProcAzFftCct.o Debug/ProcAzIFftCct.o Debug/ProcAzMocompCct.o Debug/ProcCct.o Debug/ProcInputCct.o Debug/ProcOutputCct.o Debug/ProcRgMocompCct.o Debug/ProcRmaCct.o Debug/ProcRpAdjCct.o Debug/ProcTRCct.o Debug/ProcAFEstCpt.o Debug/ProcAzFftCpt.o Debug/ProcAzIFftCpt.o Debug/ProcAzMocompCpt.o Debug/ProcCpt.o Debug/ProcInputcpt.o Debug/ProcOutputCpt.o Debug/ProcRgMocompCpt.o Debug/ProcRmaCpt.o Debug/ProcRpAdjCpt.o Debug/ProcTRCpt.o Debug/BittwareAPI.o Debug/dspDev.o Debug/GenDspDev.o Debug/LedDev.o Debug/ProSAS.o Debug/WatchDogDev.o -o Debug/MISER_SCH.exe Debug/libAutoClip.a Debug/libClip_pp.a Debug/libClip_PP_Process.a
Debug/libAutoClip.a(clp_obj.o)(.text+0xa4): In function `obj_init':
../../../../C_RT/Source/clp_obj.c:169: undefined reference to `__ctype_b_loc'
Debug/libAutoClip.a(clp_obj.o)(.text+0xa4):../../../../C_RT/Source/clp_obj.c:169: Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer (at 0x000a95e0) because the offset (-693728) is out of the allowed range, -32678 to 32767.
Maybe the problem is not linked to the LibC, but to the application having too much small data, because the first error message is "Unable to reach __ctype_b_loc (at 0x00000000) from the global pointer"...
Try with a dummy application without too much data... does it works? If yes, that's probably the reason...
Paolo
Hi Paolo,
It does work when I link to a dummy application. However, is there a way to increase the size though for global pointer though? Because we tried compiling and linking the same project under Fedora Core 4 with the gcc version 3.4.1, and it linked in just fine.
Thus, we suspect this is a NIOS-II-specific problem?
What does everybody think?
Thanks!
Shivesh
--- Quote Start ---
originally posted by paolo.gai@Jan 13 2006, 04:06 AM
maybe the problem is not linked to the libc, but to the application having too much small data, because the first error message is "unable to reach __ctype_b_loc (at 0x00000000) from the global pointer"...
try with a dummy application without too much data... does it works? if yes, that's probably the reason...
paolo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12171)
--- quote end ---
--- Quote End ---
--- Quote Start ---
originally posted by shachris23@Jan 14 2006, 03:37 AM
it does work when i link to a dummy application. however, is there a way to increase the size though for global pointer though? because we tried compiling and linking the same project under fedora core 4 with the gcc version 3.4.1, and it linked in just fine.
thus, we suspect this is a nios-ii-specific problem?
what does everybody think?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12190)
--- quote end ---
--- Quote End ---
Yes, because the Nios compiler uses a register to speedup data access. In general you cannot increase the amount of GP-relative memory, but there are two ways:
You can either
- compile using the -G0 option
or,
- put your small data (global ints, global chars, ...) inside a struct, or allocate them in another section...
you can try something like
int foo __attribute__ ((section (".data"))) = 57; int bar __attribute__ ((section (".bss"))); // initialized to 0
the section attribute must stay both in the declaration and on the definition of the variables.
There is also a section about that in the ERIKA Enterprise manual, section 4.8.4, available for free at the evidence literature page (http://www.evidence.eu.com/nios2/literature.asp
bye
Paolo
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Hi Paolo and everybody,
The problem is solved. The error happened because of the link flags that I passed when the program was linking.
At first, I didn&#39;t strictly follow Microtronix&#39;s linking flags, and just used
$(CC) -o <program> $(MYLIBS) $(LDLIBS)
And when I changed to
$(CC) $(LDFLAGS) -o <program> -lpthread $(MYLIBS) $(LDLIBS)
Voila, the program links with no problem.
So I guess the lesson learned is if it aint broke, dont mess with it.
But thanks Paolo so much for your detailed response. I sure learned new things, and I will try it next time I encountered problems like this again. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
--- Quote Start ---
originally posted by paolo.gai+jan 14 2006, 03:21 am--><div class='quotetop'>quote (paolo.gai @ jan 14 2006, 03:21 am)</div>
--- quote start ---
<!--quotebegin-shachris23@Jan 14 2006, 03:37 AM
--- quote end ---
--- Quote End ---
You can either
or,
bye
Paolo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12193)</div>
[/b]
--- Quote End ---
Sorry. To be more accurate: g++ under Windows or Linux? I knowed that g++ didn&#39;t work under Linux. Right?
--- Quote Start ---
originally posted by shachris23@Jan 17 2006, 01:16 AM
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif hi paolo and everybody,
the problem is solved. the error happened because of the link flags that i passed when the program was linking.
at first, i didn&#39;t strictly follow microtronix&#39;s linking flags, and just used
$(cc) -o <program> $(mylibs) $(ldlibs)
and when i changed to
$(cc) $(ldflags) -o <program> -lpthread $(mylibs) $(ldlibs)
voila, the program links with no problem.
so i guess the lesson learned is if it aint broke, dont mess with it.
but thanks paolo so much for your detailed response. i sure learned new things, and i will try it next time i encountered problems like this again.  http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
--- quote start ---
--- quote end ---
--- quote start ---
<!--quotebegin-shachris23@jan 14 2006, 03:37 am
--- Quote End ---
[/b]
--- Quote End ---
You can either
or,
bye
Paolo
[/b]
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12228)</div>
[/b]
--- Quote End ---
