There always is a problem with my board while I use the Flash programmer download my software project into the Flash.
the problem is: Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents 00000000 : Reading existing contents Checksummed/read 57kB in 2.4s 00000000 ( 0%): Erasing Erased 128kB in 0.6s (213.3kB/s) 00000000 ( 0%): Programming assertion "m_state == STATE_DEBUG" failed: file "nios2oci.cpp", line 237 Signal 6 But,I had download my software project into the Flash twice. Who can help me? Thanks. TenglongLink Copied
From the error message, I'd say it's quite likely you have signal integrity issues somewhere on your JTAG chain and/or a poor quality cable. It's recommended to have a USB Blaster Rev. C or better.
Good luck! - slacker- Mark as New
Thank you slacker
Yes,you're right. It is a poor quality cable,while made by myself. I have deal with it. Thank you very much. tenglong
