- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi all,
Here is what I try to do :
- I have a SOPC system with a NIOS2 with MMU. It is configured exactly as explain in : alterawiki.com/wiki/Linux_for_the_Nios_II_Processor
- I want to use device-tree so I use the kernel branch unstable-nios2mmu as suggested in the same link : alterawiki.com/wiki/Linux_for_the_Nios_II_Processor
When I try to make my Linux boot I got the following :
fault during kernel misaligned fixup @ 0xd0212794; addr 0x00000003; isn=0x20800017
Linux version 2.6.39-rc3-01078-gaf7b9ea-dirty (ben@debian) (gcc version 4.1.2) #21 Thu May 12 14:31:53 CEST 2011
bootconsole [early0] enabled
early_console initialized at 0xe4842020
On node 0 totalpages: 4096
free_area_init_node: node 0, pgdat d04d66a8, node_mem_map d04f1800
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
Kernel command line:
PID hash table entries: 64 (order: -4, 256 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 11144k/5039k RAM (2107k kernel code, 2932k data)
NR_IRQS:32
Unable to handle kernel NULL pointer dereference at virtual address 00000000
ea = d0212b98, ra = d0212b98, cause = 14
Kernel panic - not syncing: Oops
I don't know where is the issue (hardware design, kernel, erroneous device-tree).
Maybe that comes from the first "error" I get : fault during kernel misaligned fixup @ 0xd0212794; addr 0x00000003;
Does someone has any idea ?
Best regards
See attached for the device tree
My nios.h (you still need to modify it) :
Code:
#ifndef _ASM_NIOS2_NIOS_H
#define _ASM_NIOS2_NIOS_H
/* Add some defines wich should REALLY be extracted from fdt */
/* ==> REMOVE */
#define DDR2_TOP_BASE 0x10000000
#define DDR2_TOP_SPAN 16777216
/* <== END REMOVE */
* Maximum possible cache sizes on the Nios II. Only used in head.S where
* the information from cpuinfo is not yet available.
#define NIOS2_DCACHE_SIZE 2048
#define NIOS2_ICACHE_SIZE 4096
* Minumum possible cache line sizes on the Nios II. Only used in head.S
* where the information from cpuinfo is not yet available.
#define NIOS2_DCACHE_LINE_SIZE 32
/* Nios II instruction cache line size is always 32 bytes */
#define NIOS2_ICACHE_LINE_SIZE 32
#define NIOS2_ICACHE_LINE_SHIFT 5
#endif /* _ASM_NIOS2_NIOS_H */
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I found the issue. In fact the device-tree generator (sopc2dts : from .sopcinfo to .dts) does not support the version 10.1 of the timer. So I manually modify the timer description in the .dts. But I forgot to add the clock-frequency value, so I got a "NULL pointer error". The timer description should be : --- Quote Start --- //Port data_master of cpu_0 timer_0: timer@0x4842000 { compatible = "altr,timer-8.0"; reg = < 0x4842000 0x20>; interrupt-parent = < &cpu_0 >; clock-frequency = <50000000>; interrupts = < 0 >; }; //end unknown (timer_0) --- Quote End --- Now I get another issue in the boot process : --- Quote Start --- fault during kernel misaligned fixup @ 0xd02157b0; addr 0x00000003; isn=0x20800017 Linux version 2.6.39-rc3-01078-gaf7b9ea-dirty (ben@debian) (gcc version 4.1.2)# 64 Fri May 13 10:56:50 CEST 2011 bootconsole [early0] enabled early_console initialized at 0xe4842020 On node 0 totalpages: 4096 free_area_init_node: node 0, pgdat d04b2814, node_mem_map d04cd800 DMA zone: 36 pages used for memmap DMA zone: 0 pages reserved DMA zone: 4060 pages, LIFO batch:0 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4060 Kernel command line: PID hash table entries: 64 (order: -4, 256 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 11272k/4895k RAM (2119k kernel code, 2776k data) NR_IRQS:32 late time init = d0215b28 Calibrating delay loop... 22.88 BogoMIPS (lpj=45760) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 fault during kernel misaligned fixup @ 0xd02157b0; addr 0x00000003; isn=0x20800017 Linux version 2.6.39-rc3-01078-gaf7b9ea-dirty (ben@debian) (gcc version 4.1.2)# 64 Fri May 13 10:56:50 CEST 2011 bootconsole [early0] enabled early_console initialized at 0xe4842020 On node 0 totalpages: 4096 free_area_init_node: node 0, pgdat d04b2814, node_mem_map d04cd800 DMA zone: 36 pages used for memmap DMA zone: 0 pages reserved DMA zone: 4060 pages, LIFO batch:0 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4060 Kernel command line: PID hash table entries: 64 (order: -4, 256 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 11272k/4895k RAM (2119k kernel code, 2776k data) NR_IRQS:32 late time init = d0215b28 Calibrating delay loop... 22.97 BogoMIPS (lpj=45952) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 NET: Registered protocol family 16 bio: create slab <bio-0> at 0 Switching to clocksource timer NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) IPv4 FIB: Using LC-trie version 0.409 TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. [few second to wait here] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. msgmni has been set to 22 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) [few second to wait here] ttyAL0 at MMIO 0x4842020 (irq = 2) is a Altera UART console [ttyAL0] enabled, bootconsole disabled console [ttyAL0] enabled, bootconsole disabled dm9000 Ethernet Driver, V1.31 TCP cubic registered NET: Registered protocol family 17 Oops: Exception in kernel mode, sig: 4 r1: d0c1c000 r2: 00000b0e r3: d0221000 r4: 00000000 r5: 00000000 r6: 00000000 r7: ffffff80 r8: d04d2240 r9: 00000218 r10: d04b28e4 r11: d04d2360 r12: d04d2248 r13: 00000003 r14: ffffffff r15: 00000001 ra: d021647c fp: fffffbff sp: d0c1ded4 gp: 00000000 ea: d0216484 estatus: 00000001 Kernel panic - not syncing: Attempted to kill init! --- Quote End --- I will give you feed back if I found this issue Best regards- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi zben,
Did you succed to boot the kernel since you posted your message? I try to use the unstable-nios2mmu branch to use the device tree, but I have a problem. I can't find any linux-2.6/arch/nios2/boards/generic-dts/include/asm/nios.h path to modify the nios.h file.... Did you add this file or it was included in the unstable-nios2mmu branch ? With the support of device tree, did you tape only "make" in uClinuxDistr or "make path_to_device_tree.dts" in order to compile the kernel? Thank you for your help. Best regards. Pierre- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Yes I succeed to make it boot, the issues : - I update the kernel to a too new version - Same problem to the uClinux-dist directory so get the latest nios2-linux, then checkout but don't update For the nios.h I'm not sure to remember (I delete my project) but I think it was in arch/nios2/include/nios.h I compile using only make, the .dts to use is set in the .config of the kernel Best regards PS: If I remember well I have other errors after boot (like no network on the board or something like that, so I decide to wait for this branch be more mature and I return back to the trunk). I explain it in a post but Altera moderator block it...- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
It's a bit late, but I have possibly found a bug that may provokes this 'fault during kernel misaligned fixup'.
It happens when CONFIG_PASS_CMD_LINE is not set under menuconfig (because the parameter passed to early_init_devtree() is not initialized to be more precise). However, it has no relationship with the kernel panic that comes later...
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
