up3 accessing memory
I followed "Accessing Sram sdram flash and lcd on UP3 tutorial",but it don't like the tutorial showed;
when i added the Sdram and flash and generate,after i "update symble or block"
,the sram and flash is on one tri state bridge ,and the sdram is on another ?
why ,who can help me.
thanks!
Hi hanwl,
In the SOPCBuilder SDRAM Controller configuration box, make sure you selected
the "Controller shares dq/dqm/addr I/O pins" checkbox.
--Scott
