usb blaster
i want to download my design by usb blaster.but there's no usb blaster in my quartusII5.0. So i want to know where can i get the install file and if there's something that i should pay attention to during the installing process?
thx
regard
leon tsao
I'm not sure what you mean. There are no physical USB-Blasters supplied with Quartus but the drivers should be there (look for a drivers directory as part of your Quartus install).
no ,i can't find it in my altera\quartus50\driver\usb blaster directory. I think there must be some thing wrong with my software. So i want to install it separately.
THX all the same!
if some kind friend have the install file ,looking forward to sending to my email box.thank you!
my Email: leon_tsao@56.com
Here is a link to USB Blaster installation information.
http://www.altera.com/literature/lit-devkits.jsp (http://www.altera.com/literature/lit-devkits.jsp
There is no installation file other than the driver that is installed in the QuartusII directory,
Example Directory,
C:\altera\quartus50\drivers\usb-blaster
If you are using Windows, windows should detect the presents of a new USB device, if it does then you
must follow the instructions that are in the above link to the user guide for installation. If windows does
not detect a new device, then you may have something wrong with you USB port or Windows drivers to your
USB port.
Good Luck,
Brandon
