what is this problem?
Hi, everyone, I met some problems when I compiled the uClinux-dist-20060803,
make menuconfig
make vendor_hwselect SYSPTF=nios_0.ptf
make romfs(errors, ignored)
make
request.o(.text+0x994): In function `process_header_end':
/home/liaoliang/uClinux-dist/user/boa/src/request.c:560: warning: the use of `tmpnam' is dangerous,
better use `mkstemp'
Can't run cmd gzip -f -9 >> boa
collect2: ld returned 4 exit status
make[4]: *** [boa] Error 1
make[4]: Leaving directory `/home/liaoliang/uClinux-dist/user/boa/src'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/home/liaoliang/uClinux-dist/user/boa'
make[2]: *** [boa] Error 2
make[2]: Leaving directory `/home/liaoliang/uClinux-dist/user'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/liaoliang/uClinux-dist/user'
make: *** [subdirs] Error 1
I searched this problem, some guys said this was a compile error, could be ignored, but when I downloaded the zImage to the DE2 board, there was kernel panic.
Please reinstall the nios2gcc, ver 3. It is updated to support compressed flat format.
Thanks a lot, hippo!
I made it when I reinstalled the nios2gcc.
