Hi
I am a newbie with nios. After my 1st installation of Quartus 2 and nios 2 v6.1. I was able to compile Quartus Tutorial project and SOPC. When I create a new C++ application in Nios 2, then add my main.c source file. The main.c is a good file. The problem is when I start the build. I get Error: "Failed to convert tut01_nios_system.ptf to unix format using cygpath" The nios logs reports: !ENTRY com.altera.ide.core 4 0 2007-02-03 23:08:36.496 !MESSAGE Error occurred while updating SOPC Builder Cache. Launch SOPC Builder from Quartus II for more I launched SOPC Builder, but did not see anything. Any ideas! Thanks http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gifLink Copied
Were you able to resolve the issue? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif
