12748 Discussions
Nios 2 v6.1 fails build c++ (winXp SP2)
Hi
I am a newbie with nios.
After my 1st installation of Quartus 2 and nios 2 v6.1. I was able to compile Quartus Tutorial project and SOPC.
When I create a new C++ application in Nios 2, then add my main.c source file.
The main.c is a good file.
The problem is when I start the build. I get Error:
"Failed to convert tut01_nios_system.ptf to unix format using cygpath"
The nios logs reports:
!ENTRY com.altera.ide.core 4 0 2007-02-03 23:08:36.496
!MESSAGE Error occurred while updating SOPC Builder Cache.
Launch SOPC Builder from Quartus II for more
I launched SOPC Builder, but did not see anything.
Any ideas!
Thanks http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
Were you able to resolve the issue?
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ph34r.gif
