12748 Discussions
why cann't it recive interrupt
why cann't it recive interrupt,when the key is pressed, the led shows nothing
# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "D:\document\nios\low_cost\h\alt_irq.h"# include <stdio.h># include <unistd.h>
volatile int edge_capture;
static void handle_button_interrupts(void* context, alt_u32 id)
volatile int* edge_capture_ptr = (volatile int*) context;
*edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE);
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0);
static void init_button_pio()
void* edge_capture_ptr = (void*) &edge_capture;
/* Enable all 4 button interrupts. */
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE, 0xf);
/* Reset the edge capture register. */
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0x0);
/* Register the interrupt handler. */
alt_irq_register( BUTTON_PIO_IRQ, edge_capture_ptr, handle_button_interrupts );
int main (void)
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0); # ifdef BUTTON_PIO_BASE
init_button_pio();# endif
while( 1 )
if (edge_capture != 0)
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0xf);
return 0;
help me
Which design (Quartus) are you using?
If you take a look at a Nios reference design like standard or full, there are interupt buttons as well. Then if you look at the board diagnostic software example you&#39;ll see how the buttons are handled.
1. I use quartus
2. I refred to the software example,but the button can not handled.
3. is my program error ????
I have the same problem
my system consists of button_pio led_pio onchip_ram
the capture register can catch the rising edge and capture&#39;s value can change but the interrup funtionstatic void handle_button_interrupts(void* context, alt_u32 id) can not respone
i need help
thank!!!!!!
