OpenCL* for CPU
CL context destruction crash on CPU device (2013 beta)
F__Orderud
I am experiencing a strange "R6025 - pure virtual function call" crash at application termination when combining Direct3D 10 and OpenCL in the same DLL. The crash occurs even if no Direct3D calls are ever made (linking to d3d10.lib is enough). A minimal VS2010 solution with two projects to reproduce is attached. The project has no dependencies besides OpenCL and DirectX SDKs, and should built & run out of the box.
My setup:
* Windows 7 64bit SP1 (fully patched)
* Intel Core i7-3630QM CPU (Ivy Bridge)
* Intel OpenCL CPU driver (beta 2013 runtime)
Thanks in advance,
Fredrik Orderud
GE Vingmed Ultrasound (GE Healthcare)
Raghupathi_M_Intel
Thanks for the code. I'll take a look and get back to you soon.
Raghu
Raghupathi_M_Intel
Hi Fredrik,
I have reproduced and currently debugging your issue. I'll keep you posted on my findings.
Raghu
F__Orderud
The crash occurs both on Intel CPU device (Ivy-Bridge) and GPU device (HD 4000). Neither Nvidia GPUs, AMD GPUs nor CPUs with AMD OpenCL drivers suffer from this crash.
Do you have a rough estimate for when updated GPU & CPU drivers with this crash fixed will be released?
Thanks in advance,
Fredrik
Raghupathi_M_Intel
Sorry it took a while. It appears to be a bug in our common runtime. I have submitted a bug. I will let you know when a fix is available.
Raghu
F__Orderud
Thank you for the update Raghu.
F__Orderud
Raghu,
It is now close to 6 months since I reported this issue. Still, we are struggling with this crash in our product SW, even after installing the latest SDK & drivers.
Could you please give a rough estimate for when updated GPU & CPU drivers with this crash fixed will be released?
Thanks in advance,
Fredrik Orderud (GE Healthcare)
Raghupathi_M_Intel
Hi Fredrik,
Let me get back to you by the end of the day. Sorry for the delay.
Raghu
Raghupathi_M_Intel
I escalated the issue and will provide feedback when I get updates.
Raghu
SOdoe
Hi Raghu
We experience the same bug when using the RealsSense SDK (probably also using your common runtime).
Do you have an update on this issue?
Stephan
Robert_I_Intel
Stephan,
The problem is with the following line of code in your opencl.cpp:
if (cl_vendor_id == 0x8086) // only intel devices
    devices.push_back(tmp_dev);
With our current driver the platform names would be:
Intel(R) OpenCL
Experimental OpenCL 2.0 CPU Only Platform
You will put devices from both platforms into the same context, which will fail. Select only devices from the first platform by directly matching the name, and your context creation will succeed.
