OpenCL* for CPU
Dependency of Intel OpenCL runtime for Linux Ubuntu ( CPU device only ) on lsb-core package
SergeyKostrov
Valued Contributor II
*** Dependency of Intel OpenCL runtime for Linux Ubuntu ( CPU device only ) on lsb-core package ***
SergeyKostrov
During installation of Intel OpenCL runtime ( opencl_runtime_16.1.1_x64_ubuntu_6.4.0.025.tgz ) on Linux Ubuntu 16.04 LTS 64-bit in a virtualized environment of VMware Workstation 12 Player I was notified that there is a missing dependency on lsb-core package. I've terminated installation, installed lsb-core package, rebooted Linux Ubuntu, resumed installation, but the notification about missing lsb-core package was displayed again. I've continued installation and Intel OpenCL runtime was successfully installed. There are a couple of questions: - Could you explain why that dependency on lsb-core package is needed? - It looks like there is a bug in a script of the installer when packages consistency is verified since the message about missing lsb-core package did not disappear even if it was installed before. Could you check it? - Are there any plans to release an updated Intel OpenCL runtime for Linux Ubuntu 16.04 LTS 64-bit? Right now the installer informs that only 14.04 version of Linux Ubuntu is supported. Note: opencl_runtime_16.1.1_x64_ubuntu_6.4.0.025.tgz ( CPU devices only ) was used.
SergeyKostrov
I've finally completed OpenCL environment setups on Linux Ubuntu and two platforms, Intel OpenCL and AMD APP SDK, currently displayed by clinfo utility...
SergeyKostrov
[ clinfo - Part 1 ] ubuntu@ubuntu-vm:~$ clinfo Number of platforms: 2 Platform Profile: FULL_PROFILE Platform Version: OpenCL 1.2 LINUX Platform Name: Intel(R) OpenCL Platform Vendor: Intel(R) Corporation Platform Extensions: cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64 Platform Profile: FULL_PROFILE Platform Version: OpenCL 1.2 AMD-APP (1214.3) Platform Name: AMD Accelerated Parallel Processing Platform Vendor: Advanced Micro Devices, Inc. Platform Extensions: cl_khr_icd cl_amd_event_callback cl_amd_offline_devices
SergeyKostrov
[ clinfo - Part 2 ] Platform Name: Intel(R) OpenCL Number of devices: 1 Device Type: CL_DEVICE_TYPE_CPU Device ID: 32902 Max compute units: 8 Max work items dimensions: 3 Max work items[0]: 8192 Max work items[1]: 8192 Max work items[2]: 8192 Max work group size: 8192 Preferred vector width char: 1 Preferred vector width short: 1 Preferred vector width int: 1 Preferred vector width long: 1 Preferred vector width float: 1 Preferred vector width double: 1 Native vector width char: 16 Native vector width short: 8 Native vector width int: 4 Native vector width long: 2 Native vector width float: 8 Native vector width double: 4 Max clock frequency: 2800Mhz Address bits: 64 Max memory allocation: 6316211200 Image support: Yes Max number of images read arguments: 480 Max number of images write arguments: 480 Max image 2D width: 16384 Max image 2D height: 16384 Max image 3D width: 2048 Max image 3D height: 2048 Max image 3D depth: 2048 Max samplers within kernel: 480 Max size of kernel argument: 3840 Alignment (bits) of base address: 1024 Minimum alignment (bytes) for any datatype: 128 Single precision floating point capability Denorms: Yes Quiet NaNs: Yes Round to nearest even: Yes Round to zero: No Round to +ve and infinity: No IEEE754-2008 fused multiply-add: No Cache type: Read/Write Cache line size: 64 Cache size: 262144 Global memory size: 25264844800 Constant buffer size: 131072 Max number of constant args: 480 Local memory type: Global Local memory size: 32768 Kernel Preferred work group size multiple: 128 Error correction support: 0 Unified memory for Host and Device: 1 Profiling timer resolution: 1 Device endianess: Little Available: Yes Compiler available: Yes Execution capabilities: Execute OpenCL kernels: Yes Execute native function: Yes Queue properties: Out-of-Order: Yes Profiling : Yes Platform ID: 0x0000000000cf1b60 Name: Intel(R) Core(TM) i7-3840QM CPU @ 2.80GHz Vendor: Intel(R) Corporation Device OpenCL C version: OpenCL C 1.2 Driver version: 1.2.0.25 Profile: FULL_PROFILE Version: OpenCL 1.2 (Build 25) Extensions: cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64
SergeyKostrov
[ clinfo - Part 3 ] Platform Name: AMD Accelerated Parallel Processing Number of devices: 1 Device Type: CL_DEVICE_TYPE_CPU Device ID: 4098 Board name: Max compute units: 8 Max work items dimensions: 3 Max work items[0]: 1024 Max work items[1]: 1024 Max work items[2]: 1024 Max work group size: 1024 Preferred vector width char: 16 Preferred vector width short: 8 Preferred vector width int: 4 Preferred vector width long: 2 Preferred vector width float: 8 Preferred vector width double: 4 Native vector width char: 16 Native vector width short: 8 Native vector width int: 4 Native vector width long: 2 Native vector width float: 8 Native vector width double: 4 Max clock frequency: 2790Mhz Address bits: 64 Max memory allocation: 6316211200 Image support: Yes Max number of images read arguments: 128 Max number of images write arguments: 8 Max image 2D width: 8192 Max image 2D height: 8192 Max image 3D width: 2048 Max image 3D height: 2048 Max image 3D depth: 2048 Max samplers within kernel: 16 Max size of kernel argument: 4096 Alignment (bits) of base address: 1024 Minimum alignment (bytes) for any datatype: 128 Single precision floating point capability Denorms: Yes Quiet NaNs: Yes Round to nearest even: Yes Round to zero: Yes Round to +ve and infinity: Yes IEEE754-2008 fused multiply-add: Yes Cache type: Read/Write Cache line size: 64 Cache size: 32768 Global memory size: 25264844800 Constant buffer size: 65536 Max number of constant args: 8 Local memory type: Global Local memory size: 32768 Kernel Preferred work group size multiple: 1 Error correction support: 0 Unified memory for Host and Device: 1 Profiling timer resolution: 1 Device endianess: Little Available: Yes Compiler available: Yes Execution capabilities: Execute OpenCL kernels: Yes Execute native function: Yes Queue properties: Out-of-Order: No Profiling : Yes Platform ID: 0x00007fe6f0de0fc0 Name: Intel(R) Core(TM) i7-3840QM CPU @ 2.80GHz Vendor: GenuineIntel Device OpenCL C version: OpenCL C 1.2 Driver version: 1214.3 (sse2,avx) Profile: FULL_PROFILE Version: OpenCL 1.2 AMD-APP (1214.3) Extensions: cl_khr_fp64 cl_amd_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_gl_sharing cl_ext_device_fission cl_amd_device_attribute_query cl_amd_vec3 cl_amd_printf cl_amd_media_ops cl_amd_media_ops2 cl_amd_popcnt
Jeffrey_M_Intel1
Thanks for this info.  Very interesting to see this comparison!
At this time Ubuntu 14.04 is the only validated Ubuntu for this package.  I have not seen any plans or timelines for Ubuntu 16.04 support across the OpenCL SDK, cpu-only runtime, standalone Gen graphics, or Media Server Studio.  Let me check for more info.  I'll post here if there are any updates.
SergeyKostrov
I've verified a couple of tests already and results for a MemoryOptimization test, when Intel OpenCL platform is selected, don't look right. That is, bandwidth numbers are too high:
SergeyKostrov
Here is the same test on Windows 7 for NVIDIA platform:
C:\...AMD\AMD APP SDK\2.9\Samples\OpenCL\Bin\x86_64>MemoryOptimizations.exe
Platform 0 : Intel(R) Corporation
Platform 1 : NVIDIA Corporation
Platform found : NVIDIA Corporation
Selected Platform Vendor : NVIDIA Corporation
Device 0 : Quadro K1000M Device ID is 00000000003F6A60
Copy 1D FastPath        : 17.4474 GB/s
Copy 1D CompletePath    : 16.6784 GB/s
Copy 2D 32-bit (64x2)   : 16.7215 GB/s
Copy 2D 128-bit (64x2)  : 26.2851 GB/s
Copy 2D 32-bit (64x4)   : 16.441 GB/s
Copy 2D 128-bit (64x4)  : 26.0899 GB/s
Copy 2D 32-bit (8x8)    : 7.69187 GB/s
Copy 2D 128-bit (8x8)   : 22.6039 GB/s
Copy 2D 32-bit (256x1)  : 16.5217 GB/s
Copy 2D 128-bit (256x1) : 26.3462 GB/s
Copy 2D 32-bit (32x2)   : 9.48022 GB/s
Copy 2D 128-bit (32x2)  : 23.4351 GB/s
Copy 2D 32-bit (64x1)   : 9.52661 GB/s
Copy 2D 128-bit (64x1)  : 22.8418 GB/s
Copy 2D 32-bit (16x16)  : 14.9595 GB/s
Copy 2D 128-bit (16x16) : 26.0934 GB/s
Copy 2D 32-bit (16x4)   : 8.69297 GB/s
Copy 2D 128-bit (16x4)  : 24.4265 GB/s
Copy 2D 32-bit (1x64)   : 1.95445 GB/s
Copy 2D 128-bit (1x64)  : 7.63334 GB/s
Copy 1D 128-bit         : 22.8878 GB/s
NoCoal Copy 1D 32-bit   : 9.81886 GB/s
Split Copy 1D 32-bit    : 8.7023 GB/s
HasLocalBankConflicts 32-bit    : 8.80025 GB/s
NoLocalBankConflicts 32-bit     : 84.4067 GB/s
As you see peak performance numbers are around 25 GB/s.
SergeyKostrov
Unfortunately, MemoryOptimizations test on Windows 7 for Intel OpenCL platforms failed: ... C:\...AMD\AMD APP SDK\2.9\Samples\OpenCL\Bin\x86_64>MemoryOptimizations.exe -p 0 Platform 0 : Intel(R) Corporation Platform 1 : NVIDIA Corporation Selected Platform Vendor : Intel(R) Corporation Device 0 : Intel(R) HD Graphics 4000 Device ID is 000007FEF5310300 Error: clGetDeviceIDs(CL_DEVICE_DOUBLE_FP_CONFIG) failed Error code : CL_INVALID_VALUE Location : ../../../../include/SDKUtil\CLUtil.hpp:1904 Error: SDKDeviceInfo::setDeviceInfo() failed Location : MemoryOptimizations.cpp:187 ...
SergeyKostrov
>>...Let me check for more info. I'll post here if there are any updates... Thank you. Please review a dependency on lsb-core package as well.
SergeyKostrov
>>- Could you explain why that dependency on lsb-core package is needed? On another Linux Ubuntu 16.04 LTS computer I didn't do any 'apt' updates / installs related to lsb-core package and Intel OpenCL runtime ( opencl_runtime_16.1.1_x64_ubuntu_6.4.0.025.tgz ) was successfully installed. So far I don't see any runtime problems with OpenCL test applications that use Intel OpenCL CPU-only platform.
