OpenCL* for CPU
Error 1603 for GenDebuggerHost.msi when installing 2016R2
Vincent_Hindriksen
Got an error 1603 when installing 2016R2 on Windows 10:
As all errors in the logfiles look like "Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709", there is not much information there to help me fix it. Got a 1302, 1728 and 1709. These are the last two lines:
MSI (s) (98:70) [07:20:07:838]: Product: Intel® SDK for OpenCL™ Applications 2016 R2 for Windows* -- Configuration completed successfully.
MSI (s) (98:70) [07:20:07:840]: Windows Installer reconfigured the product. Product Name: Intel® SDK for OpenCL™ Applications 2016 R2 for Windows*. Product Version: 6.1.0.1600. Product Language: 1033. Manufacturer: Intel Corporation. Reconfiguration success or error status: 0.
See ways to fix this?
Sergey_L_Intel1
Hi Vincent,
Could you please collect and upload installer logs in zip archive that could found under %temp%\intel_tmp_<user_id>?
Vincent_Hindriksen
Here you go.
(file removed)
Sergey_L_Intel1
Hi Vincent,
Thank you for your feedback.
There was an error in installation Visual Studio 2015 extension. VSIXInstaller installer reported that extension is already installed  (Intel.MIDebugPackage.vsix).
MSI (s) (98:54) [07:20:10:938]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1722
CustomAction vim8C1C945FA0FC16DA5009AB658B5CDFFF returned actual error code 1001 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (98:54) [07:20:10:940]: Note: 1: 2205 2:  3: Error
MSI (s) (98:54) [07:20:10:940]: Note: 1: 2228 2:  3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709
MSI (s) (98:54) [07:20:10:940]: Product: Intel(R) Debugger for Heterogeneous Compute -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.  Action vim8C1C945FA0FC16DA5009AB658B5CDFFF, location: C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\VSIXInstaller.exe, command: /q  "C:\Program Files (x86)\Intel\OpenCL SDK\6.1\igfxdbg\host\bin\Intel.MIDebugPackage.vsix" /admin
Could you please try to remove extension manually (VS2015 -> Tools -> Extensions and Updates) and rerun OpenCL SDK installer?
Vincent_Hindriksen
I had to uninstall both the Intel Adapted MI-based Debugger and the debugger for Heterogeneous Compute, to make it work.
I expect many others to have the same problem - could the installer be adapted that these components are uninstalled before?
andre_i_
Hello I also had the same problem
I attached the log files below
Thank you
hardik_p_
hello @vincent,
        how did u disable debugger for Heterogeneous Compute to make it work??
and after disable that , is it working fine now ?
And once disable , how it can be enable again ?
