OpenCL* for CPU
1732 Discussions
I used beignet on archlinux but met some errors.
Ailick_G_
[ailick@Ailick_Mj opencl]$ optirun clinfo
drm_intel_gem_bo_context_exec() failed: No space left on device
Number of platforms                               3
  Platform Name                                   Intel Gen OCL Driver
  Platform Vendor                                 Intel
  Platform Version                                OpenCL 2.0 beignet 1.3
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short cl_khr_gl_sharing
  Platform Extensions function suffix             Intel
  Platform Name                                   NVIDIA CUDA
  Platform Vendor                                 NVIDIA Corporation
  Platform Version                                OpenCL 1.2 CUDA 8.0.0
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
  Platform Extensions function suffix             NV
  Platform Name                                   Experimental OpenCL 2.1 CPU Only Platform
  Platform Vendor                                 Intel(R) Corporation
  Platform Version                                OpenCL 2.1 LINUX
  Platform Extensions                             cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
  Platform Host timer resolution                  1ns
  Platform Extensions function suffix             INTEL
Number of devices                                 1
  Device Name                                     Intel(R) HD Graphics Haswell GT2 Mobile
  Device Vendor                                   Intel
  Device Vendor ID                                0x8086
  Device Version                                  OpenCL 1.2 beignet 1.3
  Driver Version                                  1.3
  Device OpenCL C Version                         OpenCL C 1.2 beignet 1.3
  Device Type                                     GPU
  Device Available                                Yes
  Device Profile                                  FULL_PROFILE
  Max compute units                               20
  Max clock frequency                             1000MHz
  Device Partition                                (core)
    Max number of sub-devices                     1
    Supported partition types                     None, None, None
  Max work item dimensions                        3
  Max work item sizes                             512x512x512
  Max work group size                             512
  Compiler Available                              Yes
  Linker Available                                Yes
  Preferred work group size multiple              16
  Preferred / native vector sizes
    char                                                16 / 8
    short                                                8 / 8
    int                                                  4 / 4
    long                                                 2 / 2
    half                                                 0 / 8        (n/a)
    float                                                4 / 4
    double                                               0 / 2        (n/a)
  Half-precision Floating-point support           (n/a)
  Single-precision Floating-point support         (core)
    Denormals                                     No
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Support is emulated in software               No
    Correctly-rounded divide and sqrt operations  No
  Double-precision Floating-point support         (n/a)
  Address bits                                    32, Little-Endian
  Global memory size                              2147483648 (2GiB)
  Error Correction support                        No
  Max memory allocation                           1610612736 (1.5GiB)
  Unified memory for Host and Device              Yes
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       1024 bits (128 bytes)
  Global Memory cache type                        Read/Write
  Global Memory cache size                        8192 (8KiB)
  Global Memory cache line                        64 bytes
  Image support                                   Yes
    Max number of samplers per kernel             16
    Max size for 1D images from buffer            65536 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   4096 bytes
    Pitch alignment for 2D image buffers          1 bytes
    Max 2D image size                             8192x8192 pixels
    Max 3D image size                             8192x8192x2048 pixels
    Max number of read image args                 128
    Max number of write image args                8
  Local memory type                               Local
  Local memory size                               65536 (64KiB)
  Max constant buffer size                        134217728 (128MiB)
  Max number of constant args                     8
  Max size of kernel argument                     1024
  Queue properties
    Out-of-order execution                        No
    Profiling                                     Yes
  Prefer user sync for interop                    Yes
  Profiling timer resolution                      80ns
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            Yes
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels                                __cl_copy_region_align4;__cl_copy_region_align16;__cl_cpy_region_unalign_same_offset;__cl_copy_region_unalign_dst_offset;__cl_copy_region_unalign_src_offset;__cl_copy_buffer_rect;__cl_copy_image_1d_to_1d;__cl_copy_image_2d_to_2d;__cl_copy_image_3d_to_2d;__cl_copy_image_2d_to_3d;__cl_copy_image_3d_to_3d;__cl_copy_image_2d_to_buffer;__cl_copy_image_3d_to_buffer;__cl_copy_buffer_to_image_2d;__cl_copy_buffer_to_image_3d;__cl_fill_region_unalign;__cl_fill_region_align2;__cl_fill_region_align4;__cl_fill_region_align8_2;__cl_fill_region_align8_4;__cl_fill_region_align8_8;__cl_fill_region_align8_16;__cl_fill_region_align128;__cl_fill_image_1d;__cl_fill_image_1d_array;__cl_fill_image_2d;__cl_fill_image_2d_array;__cl_fill_image_3d;
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short cl_khr_gl_sharing
Number of devices                                 1
  Device Name                                     GeForce GTX 760M
  Device Vendor                                   NVIDIA Corporation
  Device Vendor ID                                0x10de
  Device Version                                  OpenCL 1.2 CUDA
  Driver Version                                  375.82
  Device Type                                     GPU
  Device Topology (NV)                            PCI-E, 01:00.0
  Max compute units                               4
  Max clock frequency                             719MHz
  Compute Capability (NV)                         3.0
  Max work item sizes                             1024x1024x64
  Max work group size                             1024
  Preferred work group size multiple              32
  Warp size (NV)                                  32
    char                                                 1 / 1
    short                                                1 / 1
    int                                                  1 / 1
    long                                                 1 / 1
    half                                                 0 / 0        (n/a)
    float                                                1 / 1
    double                                               1 / 1        (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
    Correctly-rounded divide and sqrt operations  Yes
  Double-precision Floating-point support         (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 Yes
  Address bits                                    64, Little-Endian
  Global memory size                              2098724864 (1.955GiB)
  Max memory allocation                           524681216 (500.4MiB)
  Unified memory for Host and Device              No
  Integrated memory (NV)                          No
  Alignment of base address                       4096 bits (512 bytes)
  Global Memory cache size                        65536 (64KiB)
  Global Memory cache line                        128 bytes
  Image support                                   Yes
    Max number of samplers per kernel             32
    Max size for 1D images from buffer            134217728 pixels
    Max 2D image size                             16384x16384 pixels
    Max 3D image size                             4096x4096x4096 pixels
    Max number of read image args                 256
    Max number of write image args                16
  Local memory size                               49152 (48KiB)
  Registers per block (NV)                        65536
  Max constant buffer size                        65536 (64KiB)
  Max number of constant args                     9
  Max size of kernel argument                     4352 (4.25KiB)
  Queue properties
    Out-of-order execution                        Yes
    Profiling                                     Yes
  Prefer user sync for interop                    No
  Profiling timer resolution                      1000ns
    Run native kernels                            No
    Kernel execution timeout (NV)                 Yes
  Concurrent copy and kernel execution (NV)       Yes
    Number of async copy engines                  1
  Built-in kernels
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
Number of devices                                 1
  Device Name                                     Intel(R) Core(TM) i7-4710MQ CPU @ 2.50GHz
  Device Vendor                                   Intel(R) Corporation
  Device Version                                  OpenCL 2.1 (Build 10)
  Driver Version                                  1.2.0.10
  Device OpenCL C Version                         OpenCL C 2.0
  Device Type                                     CPU
  Max compute units                               8
  Max clock frequency                             2500MHz
    Max number of sub-devices                     8
    Supported partition types                     by counts, equally, by names (Intel)
  Max work item sizes                             8192x8192x8192
  Max work group size                             8192
  Preferred work group size multiple              128
  Max sub-groups per work group                   1
    char                                                 1 / 32
    short                                                1 / 16
    int                                                  1 / 8
    long                                                 1 / 4
    half                                                 0 / 0        (n/a)
    float                                                1 / 8
    double                                               1 / 4        (cl_khr_fp64)
    Denormals                                     Yes
    Round to zero                                 No
    Denormals                                     Yes
    Round to zero                                 Yes
  Global memory size                              12521263104 (11.66GiB)
  Max memory allocation                           3130315776 (2.915GiB)
  Shared Virtual Memory (SVM) capabilities        (core)
    Coarse-grained buffer sharing                 Yes
    Fine-grained buffer sharing                   Yes
    Fine-grained system sharing                   Yes
    Atomics                                       Yes
  Preferred alignment for atomics
    SVM                                           64 bytes
    Global                                        64 bytes
    Local                                         0 bytes
  Max size for global variable                    65536 (64KiB)
  Preferred total size of global vars             65536 (64KiB)
  Global Memory cache size                        262144 (256KiB)
  Image support                                   Yes
    Max number of samplers per kernel             480
    Max size for 1D images from buffer            195644736 pixels
    Base address alignment for 2D image buffers   64 bytes
    Pitch alignment for 2D image buffers          64 bytes
    Max 3D image size                             2048x2048x2048 pixels
    Max number of read image args                 480
    Max number of write image args                480
    Max number of read/write image args           480
  Max number of pipe args                         16
  Max active pipe reservations                    32767
  Max pipe packet size                            1024
  Local memory type                               Global
  Local memory size                               32768 (32KiB)
  Max constant buffer size                        131072 (128KiB)
  Max number of constant args                     480
  Max size of kernel argument                     3840 (3.75KiB)
  Queue properties (on host)
    Profiling                                     Yes
    Local thread execution (Intel)                Yes
  Queue properties (on device)
    Profiling                                     Yes
    Preferred size                                4294967295 (4GiB)
    Max size                                      4294967295 (4GiB)
  Max queues on device                            4294967295
  Max events on device                            4294967295
  Profiling timer resolution                      1ns
    Sub-group independent forward progress        No
    IL version                                    SPIR-V_1.0
    SPIR versions                                 1.2
  Built-in kernels
  Device Extensions                               cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_intel_exec_by_local_thread cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  Intel Gen OCL Driver
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [Intel]
  clCreateContext(NULL, ...) [default]            Success [Intel]
  clCreateContext(NULL, ...) [other]              Success [NV]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.11
  ICD loader Profile                              OpenCL 2.1
[ailick@Ailick_Mj ~]$ sudo pacman -Qs opencl
local/beignet 1.3.1-3
    An open source OpenCL implementation for Intel IvyBridge+ iGPUs
local/clinfo 2.1.17.02.09-1
    A simple OpenCL application that enumerates all available platform and device properties
local/intel-opencl-sdk 2017_7.0.0.2511-1
    Intel SDK for OpenCL Applications Linux* 2017 And OpenCL runtime for Intel Core and Xeon processors
local/ocl-icd 2.2.11-1
    OpenCL ICD Bindings
local/opencl-headers 2:2.2.20170516-1
    OpenCL (Open Computing Language) header files
local/opencl-nvidia 1:375.82-1
    OpenCL implemention for NVIDIA
Why it always telling me that drm_intel_gem_bo_context_exec() failed: No space left on device ? If anyone could help me?
