OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1736 Discussions
Kernel Builder Error: Failed to Create Context for OpenCL MIC device.
Sumedh_N_Intel
I am trying to use the Kernel Builder to build a kernel for the Intel Xeon Phi coprocessor. However, I keep getting the following messages in the log:
Using default insturtcion set architecture.
Failed to create context for Intel OpenCL MIC device...
Build Failed!
I am not quite sure of what I am doing wrong or if I am missing something.
Sumedh
Arik_Z_Intel
Which version of the SDK is installed on your machine? which Runtime version?
Yuri_K_Intel
Hi Sumedh, In addition to question from Arik I'd like to ask if you are able to run successfully any OpenCL sample/application on Xeon Phi? Just to be sure that this is Kernel Builder related issue and not something else. Yuri
Sumedh_N_Intel
I am sorry for this super late reply. I am using OpenCL-1.2-3.0.67279. How do i find which runtime version is installed on my system?
Also, I was am able to compile and run the same code on Intel Xeon Phi coprocessor without any trouble. I am just unable to get the code to compile with the Kernel Builder.
Another thing that I noticed is that this time when I use the Kernel Builder (3.0.0.1) the warnings changed a bit from my last post. Since this a shared system, I am unsure if anyone updated the system. Now the errors look like this :
Setting target instruction set architecture to: Default
Intel OpenCL Xeon Phi Coprocessor device was found!
Failed to context's devices...
Build Failed!
Thanks a lot for your help.
