OpenCL* for CPU
1733 Discussions
OpenCL Callback freezed in Intel GPU (hangs) - deadlock? pthread_cond_wait
user1900
Expected behavior (only occurs in the CPU, not in the IGPU):
1. The host creates an user event. Then, the host calls a EnqueueKernelNDRange (vector addition) and waits for the user event (WaitForEvents). When the kernel finishes it triggers the callback "callback_kernel".
2. This "callback_kernel" calls a EnqueueReadBuffer non-blocking, and when it finishes triggers the callback "callback_read".
3. The "callback_read" sets CL_COMPLETE the user event.
4. The host continues after the WaitForEvents with the content filled (buffer read).
If I select the Intel CPU as device:
./callback 0 1 0 1 1 0
platforms: 1 (0)
platform name: Intel(R) OpenCL
num devices: 2 (0)
devices: 2 (0)
context (0)
device name: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
device type: CL_DEVICE_TYPE_CPU
command queue (0)
mode CPU
create buffer a (0)
create buffer b (0)
create buffer c (0)
create program (0)
build program (0)
create kernel1 (0)
gws {1024, 1, 1}
lws {128, 1, 1}
set arg 0 (0)
set arg 1 (0)
set arg 2 (0)
set arg 3 (0)
nd range kernel1 (0)
create user event (0)
c_v 0x1420030
set event callback (0)
waiting for events
-- BEGIN callback kernel executed (0)
c_v 0x1420030
c_v[0] = 0
about to read the c buffer
blocking 0
enqueue read buffer (0)
-- END
-- BEGIN callback read executed (0)
c_v 0x1420030
c_v[0] = 1
set user event status (0)
-- END
waited for events
About to wait events: 1
3 = CL_QUEUED, 0 = CL_COMPLETE, 2 = CL_SUBMITTED, 1 = CL_RUNNING
cl_event CPU init      0  [0] = status 0 (ref 0x7f7568000a90)
CPU [0] = 1, [1] = 3, [2] = 5
about to check (first: 1)
It works.
Now, if I select the Intel IGPU (Intel Integrated GPU):
./callback 0 0 2 1 1 0
(gdb) r 0 0 2 1 1 0
Starting program: /callbacks/build/callback 0 0 2 1 1 0
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
[New Thread 0x7ffff4cd9700 (LWP 21291)]
platforms: 1 (0)
num devices: 2 (0)
devices: 2 (0)
[New Thread 0x7fffeede2700 (LWP 21292)]
[New Thread 0x7fffee5e0700 (LWP 21293)]
[New Thread 0x7fffee9e1700 (LWP 21294)]
context (0)
device name: Intel(R) HD Graphics
device type: CL_DEVICE_TYPE_GPU
command queue (0)
mode IGPU
create buffer a (0)
create buffer b (0)
create buffer c (0)
create program (0)
build program (0)
create kernel1 (0)
gws {1024, 1, 1}
lws {128, 1, 1}
set arg 0 (0)
set arg 1 (0)
set arg 2 (0)
set arg 3 (0)
c_v 0x607030
[New Thread 0x7fffec827700 (LWP 21295)]
waiting for events
c_v 0x607030
c_v[0] = 0
blocking 0
-- END
^C
Thread 1 "callback" received signal SIGINT, Interrupt.
0x00007ffff730a756 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
(gdb) bt
#0  0x00007ffff730a756 in pthread_cond_wait@@GLIBC_2.3.2 () from /usr/lib/libpthread.so.0
#1  0x00007ffff64c635b in ?? () from /opt/intel/opencl/libintelocl.so
#2  0x00007ffff648c63a in ?? () from /opt/intel/opencl/libintelocl.so
#3  0x00007ffff647b5d1 in ?? () from /opt/intel/opencl/libintelocl.so
#4  0x00007ffff63f3e75 in clWaitForEvents () from /opt/intel/opencl/libintelocl.so
#5  0x00007ffff6edca43 in ?? () from /opt/intel/opencl/libIntelOpenCL.so
#6  0x000000000040237e in main (argc=7, argv=0x7fffffffdc58) at ./src/callback.c:532
It is freezes / hangs.
It works in the Intel CPU but not in the Intel Integrated GPU (Graphics).
(gdb shows that is freezed in the `pthread_cond_wait` of the intel opencl driver).
Can anyone explain really what is the behavior with the callbacks/events and the host thread? (best practices, how to avoid deadlocks)
I need fine grained control and the fastest performance, and it looks like is callbacks, but they have weird behaviors...
    #include <CL/cl.h>
    #include <stdbool.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #define MAX_FILE_SIZE 1024000
    #include <sys/stat.h>
    #include <sys/types.h>
    typedef enum ocl_type_e_t {
      OCL_TYPE_NULL = 0,
      OCL_TYPE_CPU = 1,
      OCL_TYPE_GPU = 2,
      OCL_TYPE_IGPU = 3,
      OCL_TYPE_ACC = 4
    } ocl_type_e_t;
    const char*
    cl_device_type_to_str(cl_device_type type)
      static char* strings[] = {
        "(invalid)", // invalid
        "CL_DEVICE_TYPE_CPU",
        "CL_DEVICE_TYPE_GPU",
        "CL_DEVICE_TYPE_ACCELERATOR",
        "CL_DEVICE_TYPE_CUSTOM",
        "CL_DEVICE_TYPE_DEFAULT",
        "CL_DEVICE_TYPE_ALL",
      char* ret;
      switch (type) {
        case CL_DEVICE_TYPE_CPU:
          ret = strings[1];
          break;
        case CL_DEVICE_TYPE_GPU:
          ret = strings[2];
          break;
        case CL_DEVICE_TYPE_ACCELERATOR:
          ret = strings[3];
          break;
        case CL_DEVICE_TYPE_CUSTOM:
          ret = strings[4];
          break;
        case CL_DEVICE_TYPE_DEFAULT:
          ret = strings[5];
          break;
        case CL_DEVICE_TYPE_ALL:
          ret = strings[6];
          break;
        default:
          ret = strings[0];
          break;
      return ret;
    const char*
    file_read(char* const path)
      struct stat st;
      /* st = (struct stat*)malloc(sizeof(stat)); */
      int error = stat(path, &st);
      if (error != 0) {
        printf("Invalid file %s\n", path);
        exit(EXIT_FAILURE);
      int size_file = st.st_size;
      if (size_file > MAX_FILE_SIZE) {
        printf("File %s is bigger than the max allowed size (%d > %d bytes)\n",
               path, size_file, MAX_FILE_SIZE);
        exit(EXIT_FAILURE);
      FILE* fp = fopen(path, "r");
      if (fp == NULL) {
        printf("Error opening the file %s\n", path);
        exit(EXIT_FAILURE);
      char* const buf = (char* const)malloc(size_file);
      if (buf == NULL) {
        printf("Error allocating %d bytes for the contents of the file %s\n",
               size_file, path);
        exit(EXIT_FAILURE);
      int size_read;
      while ((size_read = fread(buf, sizeof(char), size_file, fp)) > 0) {
      fclose(fp);
      return buf;
    cl_event clb_events_waiting[100];
    int clb_events_waiting_device[100];
    int clb_events_init_read[100];
    int clb_num_events_waiting = 0;
    void
    clbWaitEvents(int * c)
      if (clb_num_events_waiting > 0){
        printf("About to wait events: %d\n", clb_num_events_waiting);
        int i;
        int waiting = 0;
        cl_event ev_waiting[100];
        printf("%d = CL_QUEUED, %d = CL_COMPLETE, %d = CL_SUBMITTED, %d = CL_RUNNING\n", CL_QUEUED, CL_COMPLETE, CL_SUBMITTED, CL_RUNNING);
        for (i=0; i<clb_num_events_waiting; i++){
          cl_int ret;
          clGetEventInfo(clb_events_waiting, CL_EVENT_COMMAND_EXECUTION_STATUS, sizeof(cl_int), &ret, NULL);
          int dev = clb_events_waiting_device;
          int init = clb_events_init_read / sizeof(int);
          printf("cl_event %s init %6d  [%d] = status %d (ref %p)\n", dev == 0 ? "CPU" : (dev == 1 ? "GPU" : "ACC"), init, i, ret, (void*)clb_events_waiting);
          if (ret != CL_COMPLETE){
            ev_waiting[waiting] = clb_events_waiting;
            waiting++;
          printf("%s [%d] = %d, [%d] = %d, [%d] = %d\n", dev == 0 ? "CPU" : (dev == 1 ? "GPU" : "ACC"), init, c[init], init + 1, c[init + 1], init + 2, c[init + 2]);
        if (waiting > 0){
          printf("about to wait %d events\n", waiting);
          clWaitForEvents(waiting, ev_waiting);
          printf("wait events finished\n");
        /* clWaitForEvents(clb_num_events_waiting, clb_events_waiting); */
    typedef struct callback_data
      cl_command_queue* queue;
      cl_mem* buf_c;
      int* c_v;
      uint size;
      cl_event* end;
      bool nested_callbacks;
      bool blocking;
    } callback_data;
    void CL_CALLBACK callback_read_fn(cl_event event, cl_int ev_status,
                                      void* user_data);
    void CL_CALLBACK callback_kernel_fn(cl_event event, cl_int ev_status,
                                        void* user_data);
    int
    main(int argc, char* argv[])
      bool use_callbacks = true;
      bool use_nested_callbacks = true;
      bool use_blocking = false;
      int numSelPlatform = 0;
      int numSelDevice = 0;
      int doUseCallbacks = 0;
      int doUseNestedCallbacks = 0;
      int doUseBlocking = 0;
      int use_type = 0;
      if (argc != 7) {
        printf("./%s (platform) (device) (type cpu 0|gpu 1|igpu 2|acc 3) (use "
               "callbacks) (use nested callbacks) (use blocking)\n",
               argv[0]);
        exit(EXIT_FAILURE);
      } else {
        numSelPlatform = atoi(argv[1]);
        numSelDevice = atoi(argv[2]);
        use_type = atoi(argv[3]);
        doUseCallbacks = atoi(argv[4]);
        doUseNestedCallbacks = atoi(argv[5]);
        doUseBlocking = atoi(argv[6]);
      cl_event end;
      uint size = 1024;
      int* a_v = (int*)malloc(size * sizeof(int));
      int* b_v = (int*)malloc(size * sizeof(int));
      int* c_v = (int*)malloc(size * sizeof(int));
      for (size_t i = 0; i < size; i++) {
        a_v = i;
        b_v = i + 1;
        c_v = 0;
      const char* kernel_str = file_read("src/kernel.cl");
      use_callbacks = doUseCallbacks;
      use_nested_callbacks = doUseNestedCallbacks;
      use_blocking = doUseBlocking ? CL_TRUE : CL_FALSE;
      cl_int st;
      cl_int err;
      int len = 256;
      char buflog[len];
      cl_uint numPlatforms = 0;
      st = clGetPlatformIDs(0, NULL, &numPlatforms);
      cl_platform_id* platforms = NULL;
      platforms = (cl_platform_id*)malloc(numPlatforms * sizeof(cl_platform_id));
      st = clGetPlatformIDs(numPlatforms, platforms, NULL);
      printf("platforms: %d (%d)\n", numPlatforms, st);
      cl_uint selPlatform = numSelPlatform; // 1;
      numPlatforms = 1;
      cl_platform_id platform = platforms[selPlatform];
      clGetPlatformInfo(platform, CL_PLATFORM_NAME, len, &buflog, NULL);
      if (buflog != NULL) {
        printf("platform name: %s\n", buflog);
      cl_uint numDevices = 0;
      st = clGetDeviceIDs(platform, CL_DEVICE_TYPE_ALL, 0, NULL, &numDevices);
      printf("num devices: %d (%d)\n", numDevices, st);
      if (st != CL_SUCCESS) {
        /* printf("explain error: %s\n", clErrorString(st)); */
        printf("error: %d\n", st);
      cl_device_id* devices = NULL;
      devices = (cl_device_id*)malloc(numDevices * sizeof(cl_device_id));
      st = clGetDeviceIDs(platform, CL_DEVICE_TYPE_ALL, numDevices, devices, NULL);
      printf("devices: %d (%d)\n", numDevices, st);
      // Context
      cl_context context;
      context = clCreateContext(NULL, numDevices, devices, NULL, NULL, &err);
      printf("context (%d)\n", err);
      // Select device
      cl_uint selDevice = numSelDevice; // 0;
      numDevices = 1;                   // clBuildProgram
      cl_device_id device = devices[selDevice];
      // Device Info
      clGetDeviceInfo(device, CL_DEVICE_NAME, len, &buflog, NULL);
        printf("device name: %s\n", buflog);
      cl_device_type type;
      clGetDeviceInfo(device, CL_DEVICE_TYPE, sizeof(cl_device_type), &type, NULL);
      printf("device type: %s\n", cl_device_type_to_str(type));
      // events
      cl_event ev_kernel;
      // CommandQueue
      /* cl_command_queue_properties props; */
      cl_command_queue queue;
      queue = clCreateCommandQueue(context, device, 0, &err);
      printf("command queue (%d)\n", err);
      // CreateBuffer
      cl_mem buf_a;
      cl_mem buf_b;
      cl_mem buf_c;
      ocl_type_e_t ocl_type;
      if (use_type == 0) {
        ocl_type = OCL_TYPE_CPU;
        printf("mode CPU\n");
      } else if (use_type == 1) {
        ocl_type = OCL_TYPE_GPU;
        printf("mode GPU\n");
      } else if (use_type == 2) {
        ocl_type = OCL_TYPE_IGPU;
        printf("mode IGPU\n");
      } else if (use_type == 3) {
        ocl_type = OCL_TYPE_ACC;
        printf("mode ACC\n");
      /* cl_mem buf_x; */
      switch (ocl_type) {
        case OCL_TYPE_IGPU:
          buf_a = clCreateBuffer(context, CL_MEM_USE_HOST_PTR, size * sizeof(int),
                                 a_v, &err);
          /* buf_a = clCreateBuffer(context, CL_MEM_READ_WRITE |
           * CL_MEM_COPY_HOST_PTR, n * n * sizeof(int), */
          /*                      Acpy, &err); */
          break;
        case OCL_TYPE_GPU:
          buf_a = clCreateBuffer(context, CL_MEM_READ_WRITE, size * sizeof(int),
                                 a_v, &err);
          break;
        case OCL_TYPE_ACC:
          buf_a = clCreateBuffer(context, CL_MEM_READ_WRITE | CL_MEM_USE_HOST_PTR,
                                 size * sizeof(int), a_v, &err);
          break;
        case OCL_TYPE_CPU:
          break;
        default:
          printf("no ocl_type defined\n");
          exit(EXIT_FAILURE);
          break;
      printf("create buffer a (%d)\n", err);
      if (err != CL_SUCCESS) {
        /* printf("create buffer error: %s\n", clErrorString(err)); */
        printf("create buffer error: %d\n", err);
      switch (ocl_type) {
        case OCL_TYPE_IGPU:
          buf_b = clCreateBuffer(context, CL_MEM_USE_HOST_PTR, size * sizeof(int),
                                 b_v, &err);
          break;
        case OCL_TYPE_GPU:
          buf_b = clCreateBuffer(context, CL_MEM_READ_WRITE, size * sizeof(int),
                                 b_v, &err);
          break;
        case OCL_TYPE_ACC:
          buf_b = clCreateBuffer(context, CL_MEM_READ_WRITE | CL_MEM_USE_HOST_PTR,
                                 size * sizeof(int), b_v, &err);
          break;
        case OCL_TYPE_CPU:
          break;
        default:
          exit(EXIT_FAILURE);
          break;
      printf("create buffer b (%d)\n", err);
      switch (ocl_type) {
        case OCL_TYPE_IGPU:
          buf_c = clCreateBuffer(context, CL_MEM_USE_HOST_PTR, size * sizeof(int),
                                 c_v, &err);
          /* buf_c = clCreateBuffer(context, CL_MEM_USE_HOST_PTR, c_rows * c_cols *
           * sizeof(int), */
          /*                        c_v, &err); */
          /*                      Acpy, &err); */
          break;
        case OCL_TYPE_GPU:
          buf_c = clCreateBuffer(context, CL_MEM_READ_WRITE, size * sizeof(int),
                                 c_v, &err);
          break;
        case OCL_TYPE_ACC:
          buf_c = clCreateBuffer(context, CL_MEM_READ_WRITE | CL_MEM_USE_HOST_PTR,
                                 size * sizeof(int), c_v, &err);
          break;
        case OCL_TYPE_CPU:
          /* buf_c = */
            /* clCreateBuffer(context, CL_MEM_USE_HOST_PTR, */
                           /* buf_c = clCreateBuffer(context, CL_MEM_READ_WRITE, */
          break;
        default:
          exit(EXIT_FAILURE);
          break;
      printf("create buffer c (%d)\n", err);
      /* b_x = clCreateBuffer(context, CL_MEM_WRITE_ONLY, n * sizeof(float), x,
       * &err); */
      /* printf("create buffer x (%d)\n", err); */
      // WriteBuffer
      /* st = clEnqueueWriteBuffer(queue, b_a, CL_FALSE, 0, n * n * sizeof(float),
      /*                           Acpy, 0, NULL, NULL); */
      /* printf("write buffer Acpy - b_a (%d)\n", st); */
      /* st = clEnqueueWriteBuffer(queue, b_b, CL_FALSE, 0, n * sizeof(float), bcpy,
       * 0, */
      /*                           NULL, NULL); */
      /* printf("write buffer bcpy - b_b (%d)\n", st); */
      // Create Program
      cl_program program;
      program = clCreateProgramWithSource(context, 1, (const char**)&kernel_str,
                                          NULL, &err);
      printf("create program (%d)\n", err);
      // Build Program
      /* st = clBuildProgram(program, numDevices, (cl_device_id*)&device, NULL,
       * NULL, */
      /*                     NULL); */
      char* opts = "-Werror";
      st = clBuildProgram(program, numDevices, (cl_device_id*)&device, opts, NULL,
                          NULL);
      printf("build program (%d)\n", st);
        /* printf("build status: %s\n", clErrorString(st)); */
        printf("build status: %d\n", st);
        char log[512];
        st = clGetProgramBuildInfo(program, device, CL_PROGRAM_BUILD_LOG, 512, &log,
                                   NULL);
        printf("build info (%d)\n", st);
        if (st == CL_SUCCESS) {
          printf("%s\n", log);
      // Create Kernel
      cl_kernel kernel1;
      kernel1 = clCreateKernel(program, "kernel1", &st);
      printf("create kernel1 (%d)\n", st);
      /* cl_kernel kernel2; */
      /* kernel2 = clCreateKernel(program, "ocl1_2", &st); */
      /* printf("create kernel2 (%d)\n", st); */
      // workgroup size
      size_t dims = 1;
      size_t gws[] = { 1, 1, 1 };
      /* size_t gws[dims]; */
      gws[0] = size; // a_rows;
      /* gws[0] = 32; */
      /* size_t* lws = NULL; */
      /* size_t lws[dims]; */
      /* size_t lws[dims] = NULL; */
      /* size_t lws[] = {0, 0, 0}; */
      size_t lws[] = { 128, 1, 1 };
      printf("gws {%lu, %lu, %lu}\n", gws[0], gws[1], gws[2]);
      if (lws != NULL) {
        printf("lws {%lu, %lu, %lu}\n", lws[0], lws[1], lws[2]);
      } else {
        printf("lws unspecified\n");
      // Set Kernel Args
      st = clSetKernelArg(kernel1, 0, sizeof(cl_mem), &buf_a);
      printf("set arg %d (%d)\n", 0, st);
      st = clSetKernelArg(kernel1, 1, sizeof(cl_mem), &buf_b);
      printf("set arg %d (%d)\n", 1, st);
      /* printf("set kernel1 arg: %d (%d)\n", 0, st); */
      st = clSetKernelArg(kernel1, 2, sizeof(cl_mem), &buf_c);
      printf("set arg %d (%d)\n", 2, st);
      st = clSetKernelArg(kernel1, 3, sizeof(int), (int*)&size);
      printf("set arg %d (%d)\n", 3, st);
      // Execute kernel
      st = clEnqueueNDRangeKernel(queue, kernel1, dims, NULL, (const size_t*)gws,
                                  (const size_t*)lws, 0, NULL, &ev_kernel);
      /* (const size_t*)lws, 0, NULL, NULL); */
      /* printf("nd range kernel1 (%d %s)\n", st, clErrorString(st)); */
      printf("nd range kernel1 (%d)\n", st);
      end = clCreateUserEvent(context, &st);
      printf("create user event (%d)\n", st);
      callback_data* user_data = (callback_data*)malloc(sizeof(callback_data));
      printf("c_v %p\n", (void*)c_v);
      user_data->queue = &queue;
      user_data->buf_c = &buf_c;
      user_data->c_v = c_v;
      user_data->size = size;
      user_data->end = &end;
      user_data->nested_callbacks = use_nested_callbacks;
      user_data->blocking = use_blocking;
      if (use_callbacks) {
        st =
          clSetEventCallback(ev_kernel, CL_COMPLETE, callback_kernel_fn, user_data);
        printf("set event callback (%d)\n", st);
      /* printf("first: %2.5f\n", c_v[0]); */
      /* print_matrix_float_s_t("c", c); */
      // ReadBuffer
      /* float* ptr = (float*)clEnqueueMapBuffer(queue, buf_c, CL_TRUE, CL_MAP_READ,
       * 0, c_rows * c_cols * sizeof(float), 0, NULL, NULL, &st); */
      /* printf("read buffer c_v - buf_c (%d)\n", st); */
      /* printf("finish queue\n"); */
      /* clFinish(queue); */
      /* printf("finished queue\n"); */
        /* clWaitForCompletion(context); */
        printf("waiting for events\n");
        /* /\* cl_event events[] = {ev_kernel}; *\/ */
        cl_event events[] = { end };
        clWaitForEvents(1, events); // ev_kernel);
        printf("waited for events\n");
        clbWaitEvents(c_v);
      } else {
        printf("about to read the c buffer\n");
        st = clEnqueueReadBuffer(queue, buf_c, use_blocking, 0, size * sizeof(int),
                                 c_v, 0, NULL, NULL);
      /* print_matrix("c_v", c_v, c_rows, c_cols); */
      free(user_data);
      clReleaseKernel(kernel1);
      /* clReleaseKernel(kernel2); */
      clReleaseProgram(program);
      clReleaseCommandQueue(queue);
      clReleaseMemObject(buf_a);
      clReleaseMemObject(buf_b);
      clReleaseMemObject(buf_c);
      /* clReleaseMemObject(b_x); */
      clReleaseContext(context);
      free(devices);
      free(platforms);
    #define THRESHOLD 0
      // check
      printf("about to check (first: %d)\n", c_v[0]);
        if (abs(c_v - (a_v + b_v)) > THRESHOLD) {
          printf("Wrong checking: a_v[%ld] = %d, b_v[%ld] = %d, c_v[%ld] = %d\n", i,
                 a_v, i, b_v, i, c_v);
          exit(EXIT_FAILURE);
      return EXIT_SUCCESS;
    void CL_CALLBACK
    callback_read_fn(cl_event event, cl_int ev_status, void* user_data)
      printf("-- BEGIN callback read executed (%d)\n", ev_status);
      callback_data* cb_data = (callback_data*)user_data;
      /* cl_command_queue queue = *(cb_data->queue); */
      /* cl_mem buf_c = *(cb_data->buf_c); */
      int* c_v = cb_data->c_v;
      cl_event end = *(cb_data->end);
      /* int size = cb_data->size; */
      cl_int st;
      printf("c_v[0] = %d\n", c_v[0]);
      /* c_v[1] = 1; */
      st = clSetUserEventStatus(end, CL_COMPLETE);
      printf("set user event status (%d)\n", st);
      // haz que salga el finish
      printf("-- END\n");
    cl_event ev_read;
    void CL_CALLBACK
    callback_kernel_fn(cl_event event, cl_int ev_status, void* user_data)
      printf("-- BEGIN callback kernel executed (%d)\n", ev_status);
      bool nested_callbacks = cb_data->nested_callbacks;
      bool blocking = cb_data->blocking;
      cl_int st;
      /* printf("about to flush\n"); */
      /* clFlush(queue); */
      /* printf("flushed\n"); */
      size_t offset = 0;
      /* size = size + 4; */
      printf("blocking %d\n", blocking);
      clb_events_waiting_device[clb_num_events_waiting] = 0;
      clb_events_init_read[clb_num_events_waiting] = 0;
      /* why it does not work? (blocking CL_TRUE) */
      st = clEnqueueReadBuffer(queue, buf_c, blocking, offset, size * sizeof(int),
                               c_v, 0, NULL, &clb_events_waiting[clb_num_events_waiting++]);
      ev_read = clb_events_waiting[clb_num_events_waiting - 1];
      printf("enqueue read buffer (%d)\n", st);
      /* size * sizeof(int), c_v, 0, NULL, NULL); */
      if (nested_callbacks) {
        st = clSetEventCallback(ev_read, CL_COMPLETE, callback_read_fn, user_data);
        /* st = clSetUserEventStatus(end, CL_COMPLETE); */
        /* printf("set user event status (%d)\n", st); */
      /* c_v[1] = 1; */
      /* st = clGetEventInfo(ev_read, CL_EVENT_COMMAND_TYPE, ); */
      /* printf("event info (%d)\n", st); */
      /* int len = 512; */
      /* char buflog[len]; */
      /* cl_command_type; */
      /* clGetEventInfo(ev_read, CL_EVENT_COMMAND_TYPE, len, &buflog, NULL); */
      /* if (buflog != NULL) { */
      /*   printf("- event: %s\n", buflog); */
      if (!nested_callbacks) {
      printf("-- END\n");
Kernel:
__kernel void
kernel1(__global int* a, __global int* b, __global int* c, int size)
  int idx = get_global_id(0);
  if (idx >= 0 && idx < size){
    c[idx] = a[idx] + b[idx];
user1900
In the snippet of gdb (IGPU) you can see the C^c (Ctrl + C), where it is freezed.
Jeffrey_M_Intel1
Thanks for this report.  I have been able to reproduce the behavior you described.  I'm investigating and hope to get back to you with more info within the next day or two.
user1900
Jeffrey M. (Intel) wrote:
Thank you very much. Glad to discover this error, I am happy to help, and if you need more samples, info about the platform or any doubt, please let me know :)
I am looking forward to know more about this problem. I was this weekend doing more tests with the HD Graphics, it failed, and I don't know how to proceed yet. I am really interested because the nested callback solution I proposed is in "theory" the only solution that seems to work in 5 different platforms, but no the HD Graphics. And I would like to get the "perfect" solution that works in any device.
I am just starting in researching, and one of my target fields is OpenCL with intel processors, coprocessors and integrated gpus. This topic will be in my mind at least for some time in the next 4 years.
Regards.
