OpenCL* for CPU
1732 Discussions
OpenCL ray tracing benchmark tested with Intel OpenCL SDK Alpha
jogshy
I've just tested your new Intel OpenCL SDK with ratGPU ( www.ratgpu.com ) which is an OpenCL ray tracing renderer / benchmark and your implementation seem to work well:
ratGPU OpenCL Intel SDK
ARNON_P_Intel
Great,
We will be glad to learn more from your experience as you are moving forward with your experiments.
jogshy
Tested it with your new Alpha SDK x64:
rtapgu intel sdk alpha x64
Your SDK x64 gives a nice speed boost ( 503s vs 565s ) plus I've found it very stable. Good job!
jogshy
Test with OpenSUSE 11.4 x64 and your Intel OpenCL 1.1 SDK beta for linux:
ratGPU 0.5.2, OpenSUSE 11.4 x64 and Intel OpenCL 1.1 SDK for linux
Works like a charm! Good job!
Btw, I think you should provide your CL sdk using a .deb / tar package for other distros.... and a x86 version won't neither hurt :p
ARNON_P_Intel
Thanks for the feedback, we do appreciate this.
Great to see this applications running on all configurations.
Have you managed to use our tips and tricks and optimize the application respectively?
jogshy
The program currently has 3 optimization paths: one for NVIDIA, other for ATI and other for Intel ( although I'm waiting for your final SDK and GPU support to make heavy optimizations ).
I try to follow your tips and tricks guide, yep. However I have a doubt. What's better, a direct memory access to a float4 pointer or a vload? Will be fantastic if you put in that guide some advices about that, pls.
