OpenCL* for CPU
1732 Discussions
Performance of "intel_sub_group_block_readN/writeN" vs "vloadN/vstoreN"
Shengquan_Y_Intel
Does subgroup extension API "intel_sub_group_block_readN/writeN" have better performance than "vloadN/vstoreN"? I did some testing, but don't see much difference between them.  Can you elaborate the read/write  performance expectation between them?
Jeffrey_M_Intel1
The driver can help a lot with optimizing memory transfers and can often get to similar results.   However, if you're already going to the trouble of using the subgroup reads and writes this can help guarantee you're getting optimal memory buffer bandwidth which could give some advantages over vload/vstore, using vector data types for memory I/O, etc.
  • Subgroup read/write is closer to what the driver would try to optimize for in any case.  If you've already arranged your data I/O to work this way this should be an optimal data access approach (for linear buffers) which will touch a minimal # of cache lines to maximize cache efficienc
  • This also optimizes the calculations needed to compute addresses and the # of addresses that need to be passed to the driver. With  subgroups only the address of the first item in the block and a length is sent, vs. an address for every work item in the subgroup
