OpenCL* for CPU
1733 Discussions
failed to create engine: clGetPlatformIDs error -1001
Zhu__Dongzhi
Intel i5-7300CPU
GPU intel HD Graphics 620
VMware Ubuntu 16.04.6 LTS
openVINO R2 with GPU
error code:
~/inference_engine_samples_build/intel64/Release/classification_sample_async -i /opt/intel/openvino/deployment_tools/demo/car.png -m ~/openvino_models/ir/FP16/classification/squeezenet/1.1/caffe -d GPU
[ INFO ] InferenceEngine:
API version ............ 2.0
Build .................. custom_releases/2019/R2_f5827d4773ebbe727c9acac5f007f7d94dd4be4e
Description ....... API
[ INFO ] Parsing inpu1
[ INFO ]     /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Creating Inference Engine
[ ERROR ] Failed to create plugin /opt/intel/openvino_2019.2.275/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so for device GPU
Please, check your environment
I run ./install_NEO_OCL_driver.sh successfully
But clinfo shows
clinfo
Number of platforms                               0
Then I tried to uninstall all the dependencies that the Intel® Graphics Compute Runtime for OpenCL™ driver components required to use the GPU plugin
And tried to ./install_NEO_OCL_driver.sh successfully again
But still can not list the GPU platform
what is the problem?
Note that i run the demo successfully with GPU in Win10
Michael_C_Intel1
Hello DongzhiZ,
On Linux the NEO RT requires the user have video group access. Can you try usermod  -a -G? This instruction is listed at the bottom of he NEO deployment page.
-MichaelC
Michael_C_Intel1
It's also possible that for some reason your ICD references aren't visible... check /etc/OpenCL/vendors to ensure references are being placed appropriately.
It's possible libOpenCL.so can be influenced by environment variables to change the default directory from which to look for implementations. See the reference at the bottom of the readme here: https://github.com/KhronosGroup/OpenCL-ICD-Loader
-MichaelC
Ben_A_Intel
I wrote an article describing how OpenCL works on Linux and how to troubleshoot installation issues.  I suspect it will be helpful to debug this issue:
https://github.com/bashbaug/OpenCLPapers/blob/master/OpenCLOnLinux.asciidoc
Let me know if it helps, or if you have any suggestions for improvement.  Thanks!
Zhu__Dongzhi
Hi Ben Ashbaugh:
  Many thanks for offering your article, it helps me a lot to understand how OpenCL works on Linux. following your way of tracing, i got these lines when run my application:
strace ~/inference_engine_samples_build/intel64/Release/classification_sample_async -i /opt/intel/openvino/deployment_tools/demo/car.png -m ~/openvino_models/ir/FP16/classification/squeezenet/1.1/caffe -d GPU
open("/usr/local/lib/libOpenCL.so.1", O_RDONLY|O_CLOEXEC) = 3
open("/etc/OpenCL/vendors/intel.icd", O_RDONLY) = 4
read(4, "/usr/local/lib/libigdrcl.so\n", 28) = 28
open("/usr/local/lib/libigdrcl.so", O_RDONLY|O_CLOEXEC) = 5
write(2, "Failed to create plugin /opt/int"..., 219Failed to create plugin /opt/intel/openvino_2019.2.275/deployment_tools/inference_engine/lib/intel64/libclDNNPlugin.so for device GPU
) = 219
then, my application was able to find the ICD loader and the ICD loader was able to enumerate and load your vendor implementation.
Note that I run ubuntu16.04 on VMware
lspci command can only get VMware VGA and no GPU is found:
00:00.0 Host bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 01)
00:01.0 PCI bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 01)
00:07.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 08)
00:07.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01)
00:07.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 08)
00:07.7 System peripheral: VMware Virtual Machine Communication Interface (rev 10)
00:0f.0 VGA compatible controller: VMware SVGA II Adapter
00:10.0 SCSI storage controller: LSI Logic / Symbios Logic 53c1030 PCI-X Fusion-MPT Dual Ultra320 SCSI (rev 01)
00:11.0 PCI bridge: VMware PCI bridge (rev 02)
00:15.0 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.1 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.2 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.3 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.4 PCI bridge: VMware PCI Express Root Port (rev 01)
Does it mean that we can't see GPU in VMware?
Thanks!
Dongzhi
Michael_C_Intel1
Hi DongzhiZ,
It looks like the issue is related to Intel® Graphics Technology hardware visibility through the virtualization stack.
Some VMware users forwarded us to this article on VMware's website. The article covers passing through PCI devices. It may be relevant for your case.
Communicating in a VMWare product related forum may yield more specific information that may apply to your configuration.
For reference:
Per Intel® Graphics Compute Runtime for OpenCL™ instructions… a native installation on Ubuntu* OS needs access to /dev/dri/* . It gets access by adding the current user to the ‘video’ group…
Given lspci configuration you  reported this represents a gap in how the iGFX device is exposed… Here is corresponding detail from my Ubuntu* OS 18.04 iGFX system:
$ lspci
00:00.0 Host bridge: Intel Corporation Skylake Host Bridge/DRAM Registers (rev 0a)
00:02.0 VGA compatible controller: Intel Corporation Iris Pro Graphics 580 (rev 09)
00:08.0 System peripheral: Intel Corporation Skylake Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31)
00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #1 (rev f1)
00:1c.1 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #2 (rev f1)
00:1c.2 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #3 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #5 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31)
00:1f.3 Audio device: Intel Corporation Sunrise Point-H HD Audio (rev 31)
00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-LM (rev 31)
02:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01)
03:00.0 Network controller: Intel Corporation Wireless 8260 (rev 3a)
3d:00.0 Non-Volatile memory controller: Intel Corporation Device f1a6 (rev 03)
$ ls /dev/dri/*
/dev/dri/card0  /dev/dri/renderD128
/dev/dri/by-path:
pci-0000:00:02.0-card  pci-0000:00:02.0-render
-MichaelC
