Hello i just build my pc and its run high idle temps:
i use arctic liquid freezer ii 360 and my idle temps is 42-55+c with 100% fan speed and my cpu usage is 0% how to fix that?
When i start download or something its up 80 or more
Processor: 13700k
Ram: kingston fury beast 32GB ddr4 (2x16GB)
Mobo: MSI MAG z690 Tomahawk
PSU: ASUS rog strix 1000W
Cpu cooler is: arctic liquid freezer ii 360
Pls help to solve it ASAP.
i tested with fortnite its run with 85-99c so it’s not good i guess
Tomorrow i get new thermal paste, so maybe it will be a bit colder, but i still waiting for any advice or help to fix this
Hello, @kszabi1
I am sorry to hear what is happening to your processor, I will gladly assist you here.
Please, answer these questions to have a better perspective of this issue:
-Did you check if the motherboard and chassis have proper airflow?
-Did you check your Cooler doesn't have any leaks, liquid loss or pump failure? Make sure is properly installed. Note that for liquid cooling, you must ensure that the pump cable and radiator fans are plugged into the appropriate board headers.
-Did you make sure you have the latest BIOS version?
-There are other tips you can follow in the Overheating Symptoms and Troubleshooting for Intel® Boxed Processors article.
Please let us know the results after applying the new thermal paste and previous steps.
Jocelyn M.
Hello kszabi1,
I hope you are doing fine.
Jean O.
Hello kszabi1,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
