Does anybody know if 500 series (11th gen) chipsets are backwards compatible with all 10th gen cpus?
Hello teoreticky
For currently four different models of Intel® 500 Series Desktop Chipsets (Z590, H570, H510, B560), there are different compatible options regarding CPU support. We recommend checking the specific chipset and reviewing under the section "Compatible Products" on the Technical Product Specifications website to see the list of supported processors. For instance:
- Compatibility for Intel® B560 Chipset
- Compatibility for Intel® Z590 Chipset
- Compatibility for Intel® H570 Chipset
- Compatibility for Intel® H510 Chipset
However, we will check this inquiry further and we will be posting back in the thread as soon as more details are available.
Andrew G.
Hello teoreticky
Andrew G.
Hello teoreticky
Thank you for your response. After reviewing this further, we would like to update this thread and provide more clarification and inform you that the Intel® 500 Series Chipset is compatible with all 10th generation Intel® processors.
We hope this clarifies your concern. If you have additional questions, please do not hesitate to contact us back.
Andrew G.
Hello teoreticky
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
